I am using multichannel modules (fibaro RGBW and double switch relay) to control different rooms/zones.
In Z-way, it seems you can only assign a zone per devise and not per instance...
Is there any way to assign a room/zone per instance and not per devise ?
For example:
Devise[2].instance[1] -> Living room spots
Devise[2].instance[2] -> Kitchen spots
Devise[2].instance[3] ->Corridor spots
Devise[3].instance[1] -> Entrance Portal
Devise[3].instance[2] -> Garage door
Many thanks,
Ben.
MultiChannel module to control different rooms/zones
You have to make your own
You have to make your own application at the moment. I have done it with OpenRemote. I have also seen references to domoticz on this forum.
Ok. That's what I thought.
I will have a look at domoticz then.
Many thanks for your quick response !
