Is the Alarm CC now fully supported?
With my sensor device (SM 103 Everspring door sensor), that supports Alarm CC to indicate tampering, it gives this:
[2013-11-26 15:37:42.250] RECEIVED: ( 01 0A 00 04 00 02 04 71 05 01 11 93 )
[2013-11-26 15:37:42.250] SENT ACK
[2013-11-26 15:37:42.251] Got frame from device 2 to controller, but command class 0x71 for device is not registered - instantiating it as not supported
[2013-11-26 15:37:42.251] SETDATA devices.2.instances.0.commandClasses.113.data = Empty
[2013-11-26 15:37:42.251] SETDATA devices.2.instances.0.commandClasses.113.data.version = Empty
[2013-11-26 15:37:42.251] SETDATA devices.2.instances.0.commandClasses.113.data.version = 1 (0x00000001)
[2013-11-26 15:37:42.252] SETDATA devices.2.instances.0.commandClasses.113.data.security = Empty
[2013-11-26 15:37:42.252] SETDATA devices.2.instances.0.commandClasses.113.data.security = False
[2013-11-26 15:37:42.252] SETDATA devices.2.instances.0.commandClasses.113.data.interviewDone = Empty
[2013-11-26 15:37:42.252] SETDATA devices.2.instances.0.commandClasses.113.data.interviewCounter = Empty
[2013-11-26 15:37:42.252] SETDATA devices.2.instances.0.commandClasses.113.data.interviewDone = False
[2013-11-26 15:37:42.252] SETDATA devices.2.instances.0.commandClasses.113.data.interviewCounter = 10 (0x0000000a)
[2013-11-26 15:37:42.252] SETDATA devices.2.instances.0.commandClasses.113.data.V1supported = Empty
[2013-11-26 15:37:42.253] SETDATA devices.2.instances.0.commandClasses.113.data.typeMask = Empty
[2013-11-26 15:37:42.253] SETDATA devices.2.instances.0.commandClasses.113.data.V1event = Empty
[2013-11-26 15:37:42.253] SETDATA devices.2.instances.0.commandClasses.113.data.V1event.type = Empty
[2013-11-26 15:37:42.253] SETDATA devices.2.instances.0.commandClasses.113.data.V1event.level = Empty
[2013-11-26 15:37:42.253] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2013-11-26 15:37:42.254] SETDATA devices.2.instances.0.commandClasses.113.data.V1event.type = 1 (0x00000001)
[2013-11-26 15:37:42.254] SETDATA devices.2.instances.0.commandClasses.113.data.V1event.level = 17 (0x00000011)
[2013-11-26 15:37:42.254] SETDATA devices.2.instances.0.commandClasses.113.data.V1event = Empty
Using code (C), I seem to be unable to get a data holder on "V1event.level"...
What is wrong?
Regards,
V.
Alarm CC & sensor tampering
Re: Alarm CC & sensor tampering
Bump this old thread I posted just before the old forum went down
I would love to get an answer on that one...
After some research, it seems that the Everspring SM103 does not report supporting the ALARM command class during the interview. The ZWave device database (http://www.pepper1.net/zwavedb/device/25) also indicates that. But still, the device supports the Alarm CC.
Is there a way to make sure ZWay is enabling full support for this command class and have the data model including it for this device?
It will have data created after first command arrived from the device. So, you can get it in C cathing this creation. Also we will add saving of "controlled" CCs, so it will survive restart.
Is this something already working in one of the latest versions (e.g. 1.5.0-rc1)?
Just tried and:
- There is no Alarm CC data for my device after the device sent it in the UI.
- There is also no data in the data updates (when doing a POST on http://ip:8083/ZWaveAPI/Data/1393433863).
Or is it only working when working with the C API?
Just tried and:
"Controlled" CCs and all non-interviewed features are not exposed to the outside (in /ZWaveAPI/Data/ and hence in the UI) and are not saved on the disc right now. But you can access them via /ZWaveAPI/Run/devices[n].instances[0].Alarm.data
