1.5.0 RC1 Shows NaN for switch status
sdh
Post by sdh »
I upgraded to 1.5.0 RC1 and the Z-Way UI shows NaN for switch state. The switches do operate but the status always shows NaN. the dimmer items shoe On/Off/Percentage correctly. Is this a known issue?
droll
Re: 1.5.0 RC1 Shows NaN for switch status
Post by droll »
I made a similar observation. The behavior of the SwitchBinary command has changed between revision 1.4.1 and 1.5.0 RC1. Executing the following command
* http://localhost:8083/JS/Run/zway.devic ... evel.value
revision 1.4.1 returns either '0' or '255' (depending the switch state). However, revision 1.5.0 RC1 returns either 'false' or 'true' (again depending the switch state).
This behavior change should be documented in the change log, as well as in the available documentation.
I just found that revision 1.5.0 is now also available (not the release candidate), but it seems to me that this revision is fully identical to the RC1 revision.
Indeed... Thanks. We will fix this in the Blue UI.
