Integrated new LED lamp Zipato in Z-Way
BrianM45
Post by BrianM45 »
Hy ;)
I use a Raspberry PI with RaZberry Daughter Card.
Do you provide integrated LED lamp Zipato in Z-Way for Razberry ?
And do you know when it will be possible ?
Thank you for any answer you can give me :D
Cordially
Re: Integrated new LED lamp Zipato in Z-Way
We need to get the device in hands to make sure it is supported. But if it conforms Z-Wave, it should work out of the box
peulberg
Post by peulberg »
I have the integrated LED lamp from Zipato here and managed to get it to work with the Razberry.
First thing to note is that if you want to integrate it into the Z-Wave network you have to not tap it gently but more or less slap it once.
Once it is included and visible for Razberry you can switch it on, off and dim it somewhat.
I was not able to create other colors than white.
