C Api
Posted: 05 Jun 2014 22:50
by tonyg
I understand that information is sent and received over the AMA0 device on the razberry, I am wondering what speed and other characteristics are set for it
thanks
Re: C Api
Posted: 06 Jun 2014 10:48
115200 8N1
But if you will write to the port yourself, turn off Z-Way.
Re: C Api
Posted: 06 Jun 2014 11:31
by tonyg
is there a documented format of the messages to and from the serial port ?
Re: C Api
Posted: 06 Jun 2014 12:01
by tonyg
I can probably decode those coming off the port and checking against the zlog, I'm more interested in the messages to z wave devices
Re: C Api
Posted: 06 Jun 2014 13:30
by tonyg
Also do you know if it uses flow control?
Re: C Api
Posted: 06 Jun 2014 16:21
by pofs
tonyg wrote:is there a documented format of the messages to and from the serial port ?
This is under NDA.
There are also open-source projects like OpenZWave, which are based on reverse engineering of the protocol. Of course, they are very incomplete.
Re: C Api
Posted: 06 Jun 2014 19:00
by tonyg
I took a look at OpenZWave, looks like a lot of devices on there. When you say under NDA, is that only zwave alliance members?
Re: C Api
Posted: 06 Jun 2014 23:41
by pofs
tonyg wrote:When you say under NDA, is that only zwave alliance members?
Not necessary. You just need to buy SDK (about $3000) and sign NDA with Sigma Designs.
You'll spend a lot of money and months of work to implement it from scratch.
It is much cheaper to use/license existing high-level SDKs. Like Z-Way
Re: C Api
Posted: 24 Jun 2014 11:55
by Shazard
This my first urge to dig out this protocol spec and write down my own "stuff". But my first attempts stomped into this dark "You'll spend a lot of money and months of work to implement it from scratch."
And then I found Z-Way which gives away JSON API for free to do exactly what I wanted to achieve... write my own "controller software" which actually means "automation software" and UIs I want...
So as I am very lazy person, I plan meanwhile spend lot less money and those month into much more productive way...
