Problems trying to display in Fahrenheit
I've gone in and tried to manually change every place in the config files I could to go from Celsius to Fahrenheit but all of my temperatures are still being displayed in Celsius. I wish my brain would allow me to freely convert between the two, but unfortunately it cannot. Can anyone help me?
Re: Problems trying to display in Fahrenheit
The file is located at /opt/z-way-server/config/Defaults.xml. Update the Fahrenheit references from 0 (zero) to 1 (one) the z-way service.
This is of course the location on a rasberry pi, I'd presume its in the same or similar location on other platforms.
i set both SensorMultilevel and ThermostatSetPoint to ONE (1) and the UI still is displaying Celsius...
help, is there something in the UI i'm missing???
edit:
after some time after restarting the z-way-server it started to display F but with C on the UI (i.e. 76C) and the slider to change the temp went from 0 - 40...
until this gets fixed i returned the settings back to Celsius.
edit:
