zstick (with z-way-server) issue
Posted: 18 Nov 2014 21:44
I have a zstick (with z-way-server) and I usually connect to it via a network/usb server (i.e. virtual com port) in ubuntu.
For some reason, with this particular unit, the device will not connect properly, failing to create a virtual com port...
i.e. /dev/serial/by-id/xxxxxxxxxxxxxxxxxxxxxxxxxx
Could this be a known issue with the stick itself, not completing some sort of handshake etc?
Never seen this before.
Is the USB stick upgradeable? Could this be a firmware issue?
Neil
Neil
