Hi guys,
I am testing the razberry to make it work with my free home automation solution.
My software actually works only for 433Mhz devices and I have to make it work soon for zwave material through the razberry card (zway), maybe USB stick as well?
http://spanaer.com
As you could imagine, devices are not cheap as I would like ... maybe that is the price for quality stuff.
And (re)sellers are not very excited to give free materials even if your solution can potentially increase their business.
That is why I am working with only 2 devices :
- TKBHOME TZ67 (dimmer)
- Fibaro Wall Plug (switch with power sensor)
I have been supprised to discover that for switches/dimmers values to turn on/off, change level can be different.
- for TKBHOME TZ67 : level -> 1-99
- for Fibaro Wall Plug : level -> 0|255
Could you contribute to answer to this post and give the values for your own switch/dimmer ?
Maybe I will come back with similar questions for sensors.
Many thanks.
switch/dimmer max and min
Re: switch/dimmer max and min
Hi Sevy,
Your project looks really very cool.
Maybe this link will help you:
http://manuals.zwaveeurope.com/
Values for dimmers seem to be 0-99 | 255
Values for switchs seem to be 0|255
