razberry doesn't see devices
Posted: 28 Dec 2014 07:20
Problem:
When attempting to include a device the RaZberry doesn't find any. I have four devices but I am only trying to include a Nexia RP200 Home Dimmer Module, Freq 908.42 MHz. I know the dimmer device works as I can use the Nexia bridge to include the device (which I then exclude). The RaZberry does communicate as I can see data sent/received in the log file. Also the red led lights up when I attempt to include a device and goes out when I stop the include.
How can I tell if my RaZberry is on the correct frequency for the US as I understand it supports a number of countries? I have the zway and OpenRemoteHelpers modules configured.
Just trying to get my system running.
Here is the info on my system:
uname -a
Linux raspberrypi 3.12.35+ #730 PREEMPT Fri Dec 19 18:31:24 GMT 2014 armv6l GNU/Linux
file /bin/ls
/bin/ls: ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.26, BuildID[sha1]=0x7f981e03f231371c5feaaeab28d9e23639e57cd3, stripped
Z-Way version v2.0.0 from 2014-12-08 19:54:26 +0300 (build a064f5408850947aed035bc9170e1fa04f0fd2ec)
cURL 7.26.0 likely has DNS timeout bug. Please update cURL. Disabling sync DNS timeouts for now.
Module modhttp.so loaded
Module modzwave.so loaded
Module modenocean.so loaded
Module modws.so loaded
Module modhomekit.so loaded
Module moddhs.so loaded
Role in Network
Node Id: 1
Home Id: 0xf209b6ea
Primary Role: yes
Primary Capability: yes
SUC/SIS in network: No SUC/SIS present
Hardware
Vendor: RaZberry by Z-Wave.Me
Vendors Product ID: 2/3
Z-Wave Chip: ZW0301
Firmware
Library Type: static controller
SDK Version: 4.54.01
Serial API Version: 04.02
Log File info:
<NOTE: I don't know if this means anything but setting the SUC/SIS failed>
uname -a
file /bin/ls
Role in Network
Node Id: 1
Home Id: 0xf209b6ea
Primary Role: yes
Hardware
Z-Wave Chip: ZW0301
Firmware
Log File info:
2014-12-27 21:14:01.904] [I] [zway] Adding job: Set new SUC/SIS
[2014-12-27 21:14:01.904] [I] [zway] Removing job: Get controller capabilities
[2014-12-27 21:14:01.914] [D] [zway] SENDING: ( 01 07 00 54 01 01 00 01 AD )
[2014-12-27 21:14:01.928] [D] [zway] RECEIVED ACK
[2014-12-27 21:14:01.928] [D] [zway] RECEIVED: ( 01 04 01 54 00 AE )
[2014-12-27 21:14:01.928] [D] [zway] SENT ACK
[2014-12-27 21:14:01.928] [I] [zway] Job 0x54 (Set new SUC/SIS): Failed
[2014-12-27 21:14:01.929] [D] [zway] Job 0x54 (Set new SUC/SIS): fail
[2014-12-27 21:14:01.929] [I] [zway] Removing job: Set new SUC/SIS
<NOTE: More data from when I pressed the Start Inclusion from the expert menu>
[2014-12-27 21:16:46.926] [I] [zway] Adding job: Add/re-include node to network
[2014-12-27 21:16:46.936] [D] [zway] SENDING (cb 0x01): ( 01 05 00 4A C1 01 70 )
[2014-12-27 21:16:46.938] [D] [zway] RECEIVED ACK
[2014-12-27 21:16:46.940] [D] [zway] RECEIVED: ( 01 07 00 4A 01 01 00 00 B2 )
[2014-12-27 21:16:46.940] [D] [zway] SENT ACK
[2014-12-27 21:16:46.940] [D] [zway] SETDATA controller.data.lastIncludedDevice = Empty
[2014-12-27 21:16:46.940] [D] [zway] SETDATA controller.data.lastExcludedDevice = Empty
[2014-12-27 21:16:46.941] [I] [zway] Job 0x4a (Add/re-include node to network): Ready to add - push button on the device to be added
[2014-12-27 21:16:46.941] [D] [zway] SETDATA controller.data.controllerState = 1 (0x00000001)
[2014-12-27 21:17:07.433] [I] [zway] Adding job: Add/re-include node to network
[2014-12-27 21:17:07.433] [D] [zway] SETDATA controller.data.controllerState = 17 (0x00000011)
[2014-12-27 21:17:07.433] [D] [zway] SENDING: ( 01 04 00 4A 05 B4 )
[2014-12-27 21:17:07.435] [D] [zway] RECEIVED ACK
[2014-12-27 21:17:07.435] [I] [zway] Removing job: Add/re-include node to network
[2014-12-27 21:17:07.486] [D] [zway] RECEIVED: ( 01 07 00 4A 01 06 00 00 B5 )
[2014-12-27 21:17:07.486] [D] [zway] SENT ACK
[2014-12-27 21:17:07.486] [I] [zway] Job 0x4a (Add/re-include node to network): Cancelling job: Add/re-include node to network
[2014-12-27 21:17:07.486] [I] [zway] Removing job: Add/re-include node to network
[2014-12-27 21:17:07.487] [D] [zway] SETDATA controller.data.controllerState = 0 (0x00000000)
[2014-12-27 21:17:27.553] [D] [zway] Job 0x4a: deleted from queue
[2014-12-27 21:17:27.595] [D] [zway] Job 0x4a: deleted from queue
[2014-12-27 21:40:20.913] [I] [zway] Adding job: Get routing table line
[2014-12-27 21:40:20.914] [D] [zway] SENDING: ( 01 06 00 80 01 00 00 78 )
[2014-12-27 21:40:20.915] [D] [zway] RECEIVED ACK
[2014-12-27 21:40:20.919] [D] [zway] RECEIVED: ( 01 20 01 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5E )
[2014-12-27 21:40:20.919] [D] [zway] SENT ACK
[2014-12-27 21:40:20.920] [D] [zway] SETDATA devices.1.data.neighbours = byte[0]
[2014-12-27 21:40:20.920] [D] [zway] ( zero-length buffer )
[2014-12-27 21:40:20.920] [I] [zway] Job 0x80 (Get routing table line): List of neighbours for node 1: [ ]
[2014-12-27 21:40:20.920] [D] [zway] Job 0x80 (Get routing table line): success
[2014-12-27 21:40:20.920] [I] [zway] Removing job: Get routing table line
[2014-12-27 21:40:41.025] [D] [zway] Job 0x80: deleted from queue
