Debug Queue
Posted: 04 Jan 2015 23:40
by skiv71
I'm just looking at the Queue and whilst I can see jobs lined up for a specific node, but what is the device has more than one instance?
I'm looking to cross ref in an attempt to prevent duplicate entries etc. but if I have a node 3 with instances 1 and 2 and a specific command class, I need to know which instance the queued command relates to.
Neil
Re: Debug Queue
Posted: 05 Jan 2015 00:04
by skiv71
... looks to me as if the payload data tell's all... think I've figured out the node and instance as fields 1 and 6....
Re: Debug Queue
Posted: 05 Jan 2015 01:30
by pofs
1) It really is in payload, but you shouldn't rely on it to be at specific offset, because of possible encapsulations;
2) It is encrypted for secure jobs, so you cannot access it;
3) You are not supposed to access the queue directly, queue viewer is made only for debugging purposes;
4) The queue automatically removes/rearranges duplicate jobs where appropriate, so there's no need to do anything with it.
Re: Debug Queue
Posted: 05 Jan 2015 01:45
by skiv71
Ah, hmmm... I was hoping to interrogate the queue to see if the command request I have in mind is already present.
I'm trying to trim the queue down.
I am interrogating the queue via a wget and there are duplicate jobs
Re: Debug Queue
Posted: 05 Jan 2015 02:18
by pofs
Some duplicate jobs are allowed for a reason.
But usually you shouldn't see two jobs for the same node having the same payload.
If you provide a specific example of a job added twice, we may discuss why there's a duplicate.
Re: Debug Queue
Posted: 05 Jan 2015 02:24
by skiv71
I don't doubt you're right...
I think, in the meantime, I'm gonna implement my own duplicate command filtering between my system and the z-way server :)
Re: Debug Queue
Posted: 05 Jan 2015 15:17
by skiv71
I have a solution now, but I'd much rather know the actual controller command queue, but in the absence of instance info, any decision's I make wouldn't be reliable.
I'm sure I've seen some user's log's on here for the queue show instance info though.
Is this something that was introduced in later versions?
Re: Debug Queue
Posted: 06 Jan 2015 05:37
by pofs
skiv71 wrote:I'm sure I've seen some user's log's on here for the queue show instance info though.
You must have been mistaken, as there's no instance info there.
