Page 1 of 2
Starting HTTP server on port xxxx...
Posted: 22 Jan 2015 14:22
by magadheera
Z-way v 1.7.0. After restarting the system z-way stucks here at Starting HTTP server on port xxxx..., and not moving further. Can anyone has the same problem. How to solve this problem.
Re: Starting HTTP server on port xxxx...
Posted: 22 Jan 2015 15:14
by pz1
Did it work before? It is hard to say with the minimal information with the minimal info you have.
Version 1.7.0. is rather old. You advised to upgrade to 2.0, which is much more stable. That may not immediately solve your problem, but will be a better starting point
Posted: 22 Jan 2015 15:31
by magadheera
Yes, it was working before. Sorry for the inconvinience to upgrade the sys will take some time. Feel better if some solution present for this prob with the same version.
It was working fine before, Just after restarting the sys it stops working.
attached screenshots from the z-way log.
Posted: 27 Jan 2015 01:35
Why is your log file specified to /bin/z-way-log????
Posted: 28 Jan 2015 12:59
by magadheera
Frankly speaking,I dont know. This can be reason of this error?
Posted: 28 Jan 2015 13:37
by pz1
magadheera wrote:Frankly speaking,I dont know. This can be reason of this error?
It is at least a sign that you did not follow the standard installation procedure. So it is hard to guess. Besides not
many users are on these older versions, so it will be hard to find someone who can repeat/check some of your issues.
If you do need to stay on this 1.7.0 version, I advise you to upload a zipped the relevant logfile here, so the experts can have a look.
Posted: 29 Jan 2015 10:24
by magadheera
Here is compt log from the z-way.
Posted: 29 Jan 2015 10:26
by magadheera
Here is compt log from the z-way. And one more thing i have noticed is that config.xml file is missing in this situation.
when i use cat config.xml, returns file not found error.
Posted: 29 Jan 2015 14:11
by magadheera
Loading ZDDX index from /data/z-way/config/zddx/ZDDX.indxml
[2015-01-29 11:10:32.239] Failed to read ZDDX index
[2015-01-29 11:10:32.240] Failed to get a list of products. Check index file
Can please explain wht does above error means in Z-way.In my sys i dont have such file called ZDDX.indxml.
I have splittted log file, because of tits size.
Posted: 29 Jan 2015 17:49
by pz1
magadheera wrote:Here is compt log from the z-way. And one more thing i have noticed is that config.xml file is missing in this situation.
Sorry I do not see an attached log file attached to that post
