sensor data update with wakeup
Posted: 04 Feb 2015 14:10
by opperman
Hello forum,
I have a problem with a 4in1 Routing Binary Sensor (motion, tamper, luminescence, door/window and temperature). The sensor data from motion, tamper and door/window are updated while activated but the trigger from motion is not deactivated after wakeup. This means in expert mode I can see the trigger point of time but in automation mode I can only see "Motion on", which gives me a false-positive information. The other sensor-data like temperature and luminescence are not updated after wakeup, neither. Only the door/window signal is correct.
The hint in the Razberry "Known problems" that a sensor has to be in life-line association group 1 did not help, the association is already asigned.
I hope there is anybody who had the same problem and could solve it.
Christian
