Z-Wave Plus
Posted: 07 Mar 2015 05:46
by Mike Yeager
This is probably a question that has been asked but I didn't see it. Does Razberry support any of the Z-Wave Plus stuff? I don't see a lot of it out there yet but I'd hate to grab a device and not be able to use it...
Re: Z-Wave Plus
Posted: 07 Mar 2015 06:21
by pofs
Yes, the new gen 5 RaZberry fully supports Z-Wave Plus.
Old gen 3 RaZberry partially supports it (shorter distance, no power level tests) with 2.0 software.
Re: Z-Wave Plus
Posted: 09 Mar 2015 19:55
by Mike Yeager
How do I know wgat version of the Razberry I have and by 2.0 software I am assuming you are referring to the software that runs on the RPi.
Re: Z-Wave Plus
Posted: 09 Mar 2015 20:24
by pz1
Mike Yeager wrote:How do I know what version of the Razberry I have and by 2.0 software I am assuming you are referring to the software that runs on the RPi.
In the new UI for me
http://raspberry_IP:8083/expert/#/network/controller
Z-Wave Chip: ZW0500
Re: Z-Wave Plus
Posted: 10 Mar 2015 02:52
by RottenMutt
Amazon is dumping the old stuff still, only buy if the description say version 5.
Re: Z-Wave Plus
Posted: 10 Mar 2015 18:46
by cpighin
A couple of days ago I bought from Amazon the razberry card and in its description was not reported the item version.
When the card will arrive, how can I check if it is version 5?
pz1 wrote:In the new UI for me
CODE: SELECT ALL
Z-Wave Chip: ZW0500
I read what pz1 wrote (the link posted doesn't work for me), but I didn't understand what to do since I'm new to Z-wave technology and to this forum. Be patient with me
Claudio
Re: Z-Wave Plus
Posted: 10 Mar 2015 21:38
by pz1
I only works if you have
- Physically installed the RaZberry or UZB1
- Installed Z-Wave binding via the HA user Interface
Re: Z-Wave Plus
Posted: 11 Mar 2015 06:26
by RottenMutt
you have to build your Pi, download and install the image and on your sd card. when you first boot, do plug it into a monitor and keyboard as it will display your Pi's ip address on your lan. the default user is Pi, and password is raspberry. update the distribution with apt-get do upgrade and update, then update the zwave software.
the link provided above is the ip address of you Pi.
here is the image and software info...
http://razberry.z-wave.me/index.php?id=24
Re: Z-Wave Plus
Posted: 11 Mar 2015 10:33
by cpighin
Thank you RottenMutt for yourmore detailed instructions.
I will try to follow them!
Claudio
Re: Z-Wave Plus
Posted: 12 Mar 2015 18:46
by cpighin
I got my RaZberry card and I am confident that it mounts the new wave transceiver "Sigma Design ZM5202" as reported on the specification data shit.
Claudio
