z-way server v2+
Posted: 23 Mar 2015 22:31
by skiv71
I'm just looking at integrating the new v2+ release of z-way server into my system.
With the 1.7.x i was using, I was able to seperate (and isolate) different configurations, which allowed me to run multiple controller instances.
I was able to do this by specifying the path for http-root and it works fine.
I see the new (v2+) config.xml has a lot of entries removed and does not appear to cater for custom http-root paths.
Is this correct, or can I apply the same parameter's via the xml?
Neil
Re: z-way server v2+
Posted: 24 Mar 2015 01:36
by pofs
You need to edit main.js for now, http-root is passed as a parameter when creating WebServer object.
It is not in config anymore because of the modular nature of the new js engine. We'll probably move it into some sort of config later, but for now we have a lot of other things to do.
