[Bug] Deactivate remote access
Posted: 02 Aug 2015 03:12
by Genius
Hi there,
there seems to be a bug, when I deactivate the Remote Access over
http://IP:8084 and save it, its activated after a restart again.
Would be nice if you can fix it. I don't want to have an open door on my raspberry.
Any idea, how I can deactivate it forever?
BR
Patrick
Re: [Bug] Deactivate remote access
Posted: 02 Aug 2015 16:49
by Genius
Whoever is interested in:
Remove this service from autostart:
sudo service mongoose stop
sudo service zbw_connect stop
sudo update-rc.d -f mongoose remove
sudo update-rc.d -f zbw_connect remove
Guess thats the only way that "Razberry grants you 100% control of any cloud service usage of your system"
Just a suggestion from me, maybe let the user decide whether he wants to install that cloud software.
Posted: 02 Aug 2015 17:35
by pz1
Genius wrote:there seems to be a bug, when I deactivate the Remote Access over
Once I have saved this deny access setting, it does not re-occur on my v2.0.2-rc1 rig
- Deactivate.PNG (9.84 KiB) Viewed 8732 times
Posted: 02 Aug 2015 19:17
by Genius
pz1 wrote:Genius wrote:there seems to be a bug, when I deactivate the Remote Access over
If you uncheck and save this option the service is shut down fine. But after restart the service run again, although this option is unchecked.
You can check if the service is still running by go to
https://find.zwave.me/ and see if your IP is shown up, or check via console if the service is still running:
ps ax|grep zbw_connect
Btw. I use v2.0.1
Posted: 02 Aug 2015 22:27
by pz1
I don't know this ps command very well. But I think it does not show an active zbw_connect.
I tried your command for both cron and zbw_connect:
- grep.PNG (6.13 KiB) Viewed 8722 times
