UZB stick updated Firmware before bootloader
Posted: 13 Aug 2015 09:38
by steinis
Hi
I have just bought a UZB stick and a seperate license. But I pressed the wrong button (Firmware) so now I can't install the bootlader. How can I "downgrade" UZB stick and try again?
thanks for input.
Re: UZB stick updated Firmware before bootloader
Posted: 15 Aug 2015 17:52
by steinis
No solution for this?
Posted: 16 Aug 2015 16:08
by SgtBilko
I think I have the same issue.
Z-Way will not communicate with the UZB. Expert Mode says "Error Handling data from Server". Log file has "Opened device: /dev/ttyAMA0", "Job 0x07 (Get controller info and supported function classes): No ACK received before timeout" and "Notification: critical (z-wave): Cannot start Z-Wave binding: Error: Bad data - communication failed". I havn't printed full log becasue I suspect I have the same problem as Stennis.
I look forward to hearing from you as I bought 2 of the UZB's becuase I thought hte 1st was defective. I have a paid for licence.
SgtBilko
Posted: 16 Aug 2015 18:31
by pz1
For the UZB1 you need to set /dev/ttyACM0 in the Zwave setup
Posted: 16 Aug 2015 21:13
by SgtBilko
Thank you pz1. Where do I find "Zwave setup" ?
Posted: 16 Aug 2015 23:04
by steinis
I don“t think this is the same problem. I can't install the boot loader (Whatever that does:P?) because the firmware is up to date.
And how do you see that you have used your license key?
Posted: 17 Aug 2015 10:49
by pz1
SgtBilko wrote:Thank you pz1. Where do I find "Zwave setup" ?
In the smarthome interface under APPS is the Zwave module configuration
Posted: 17 Aug 2015 18:42
by SgtBilko
Brilliant... thank you very much for your help, pz1
Problem.....Serial Port to Z-Wave dongle is already set up to /dev/ttyACM0
Posted: 17 Aug 2015 18:51
by SgtBilko
In case it helps here is extract of log file
[2015-08-17 16:47:24.810] [D] [zway] Opened device: /dev/ttyAMA0
[2015-08-17 16:47:24.811] [D] [zway] Worker thread successfully created
[2015-08-17 16:47:24.813] [D] [zway] Worker thread entry point
[2015-08-17 16:47:24.823] [zway] Adding job: Get controller info and supported function classes
[2015-08-17 16:47:24.823] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2015-08-17 16:47:25.031] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2015-08-17 16:47:25.031] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2015-08-17 16:47:25.235] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2015-08-17 16:47:25.236] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2015-08-17 16:47:25.440] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2015-08-17 16:47:25.440] [W] [zway] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2015-08-17 16:47:25.440] [D] [zway] Job 0x07 (Get controller info and supported function classes): fail
[2015-08-17 16:47:25.440] [C] [zway] Get Serial API Capabilities returned zero.
[2015-08-17 16:47:25.441] [zway] Removing job: Get controller info and supported function classes
[2015-08-17 16:47:25.451] [D] [zway] Worker thread exit point
[2015-08-17 16:47:25.452] [D] [zway] Worker thread successfully finished
[2015-08-17 16:47:25.454] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
[2015-08-17 16:47:25.489] [core] Notification: critical (z-wave): Cannot start Z-Wave binding: Error: Bad data - communication failed
Posted: 18 Aug 2015 18:21
by SgtBilko
Stennis
You were right I didn't have the same problem (see viewtopic.php?f=3419&t=21791 for my solution).
I am sorry to have hijacked your thread, I hope someone can help you.
