Q: How to upgrade to 2.02-RC
elRedeo
Post by elRedeo »
just a simple stupid question, but how can i update the system from 2.0.1 to 2.0.2-RC ?
I was trying by the web interface and entered the 2.0.2-RC, also the install script via the bash.
Each time I stuck at 2.0.1.
Can me please somebody give a hint?
Kind regards
elRedeo
txb
Re: Q: How to upgrade to 2.02-RC
Post by txb »
I had the same problem.
The issue seems to be that there is no release called "v2.0.2-rc" or even "v2.0.2-rc2". Trying to use the command line will just terminate for a non-valid release. The UI will look like it's doing something, but just stops attempting to find that download.
What did work for me is using the target "v2.0.2-rc2-beta". That updated the server component .. or at least it now reports that version.
elRedeo
Post by elRedeo »
This brings me the 2.0.1
Install specific version
You can specify exact version of Z-Way to install by adding version /vx.y.z after install word:
wget -q -O - razberry.z-wave.me/install/v2.0.2-rc| sudo bash
does not work, because the directory c2.0.2-rc does not exists on the web server.
elRedeo
Post by elRedeo »
Tried this an i got the install script for the beta, this looks promising, installing , but not response on web.
