Z-Way - modify add user code to Kwikset?
Posted: 02 Sep 2015 08:58
by branco
I am considering purchasing either a razberry or just the uzb and run Z-way. My question is can Z-way allow user code management of the Kwikset smart lock? This is, I would like to remotely manage my access codes to smartlock, I have been looking for a HA that is able to do this but so far I haven't been able to find any that I can install on my Raspberry and use it..
Re: Z-Way - modify add user code to Kwikset?
Posted: 05 Sep 2015 17:06
by branco
I am very interested in buying the raspberry daughter board or the UZB but I really would like to know if anyone knows if we can program the codes for Kwikset in Z Way??? Or even schedule timing for codes?
Posted: 12 Sep 2015 03:49
by Mike Yeager
It is possible. I store my users in a SQLite3 database and access it from a web interface. I can modify the user list and then "commit" the changes to the locks. Haven't played with it lately as I got sidetracked with other projects. I'm using the HTTP API from Python.
Posted: 22 Nov 2015 20:20
by hp1
Can you share the code and URLs that you use to post the user codes and then read them back?
I'm hoping to do something similar, have a bash script that pushes a code to the door the morning when we have the maids come, and then revoke it at the end of the day.
Posted: 06 Dec 2015 05:05
by Mike Yeager
Check out this post. It will give you a quick look at it. Also, if you search for my posts, you'll get a lot more to go on.
viewtopic.php?f=3419&t=20365
