Popp APP and iOS
Posted: 14 Sep 2015 21:53
by diemue
Is it possible to use the iOS Popp App with the z way server? After installing/configuring the Popp App, i can“t login into z way server.
Re: Popp APP and iOS
Posted: 15 Sep 2015 01:34
by gijoecool
It works for me locally. It just takes a while to load. I'm not sure if it works remotely though.
Posted: 16 Sep 2015 06:25
by viper384
Make sure remote access is enabled. Go to http://yourip:8084 - select a password and make sure that remote access is enabled in advanced. Go to find.zwave.me type in your credentials, it should you log into your system, works remotely. After you confirm that works, you should be able to easily configure the Popp App (at least on Android).
http://razberry.z-wave.me/docs/RaZberry500_QSG_en1.pdf
