SOLVED: Schedule switch doesn't switch
Coffeelover
Post by Coffeelover »
I recently registered since I'm a newby in smart home.
I'm using the z-way stick for wd Nas and already included the Fibaro Wall Plug and the multi sensor.
Using a scene I could recently set up a configuration to activate the switch motion-controlled, but I failed to create a schedule based setting. (scheduled scene fails as well as logical rule).
Maybe anyone can assist me in the first steps?
Mike Yeager
Re: Schedule switch
Post by Mike Yeager »
If you're trying to check for one condition and then another, try making sure the first entry into the logical rule is NESTED. I was trying to create one condition and then nest the next under it but discovered that the first entry had to be NESTED and then created the way I thought.
Coffeelover
Re: Schedule switch
I could solve the problem: the time was set correctly, but the time zone on the NAS was wrong... Therefore my scheduled program did not work.
