ios zway authentication - help
pofs
Re: ios zway authentication - help
Post by pofs » 16 Oct 2015 22:53
Are you not specifying content type for post request?
yzheng
Post by yzheng » 16 Oct 2015 23:37
pofs wrote:Are you not specifying content type for post request?
This is my code, I have not specified content type for post request.
AFHTTPRequestOperationManager *manager = [AFHTTPRequestOperationManager manager];
     manager.responseSerializer = [AFJSONResponseSerializer serializer];
     manager.requestSerializer.cachePolicy = NSURLRequestReloadIgnoringLocalAndRemoteCacheData;
     [manager.requestSerializer setAuthorizationHeaderFieldWithUsername:@"admin" password:@"admin"];
     [manager POST:@"http://192.168.0.12:8083/ZAutomation/api/v1/devices/ZWayVDev_zway_2-0-37/command/on" parameters:nil
     success:^(AFHTTPRequestOperation *operation, id DATA) {
     NSLog(@"notifications: %@",DATA);
     } failure:^(AFHTTPRequestOperation *operation, NSError *error) {
     NSLog(@"getNotifications Error : %@",error.description);
pofs
Post by pofs » 17 Oct 2015 00:09
Seems the serializer doesn't specify content type when there's no content.
Why using POST with empty parameters at all?
GET should do the same without this error.
yzheng
Post by yzheng » 17 Oct 2015 00:31
pofs wrote:Seems the serializer doesn't specify content type when there's no content.
Thanks pofs. It works now. I thought I should use POST for all the commands sending to the device.
During the testing through the web interface these days, I noticed Razberry can be non-responsive (request time out) sometime. I have to reboot it to fix the issue. Is there any solution other than reboot?
Another issue is, at the moment, I am using local ip to control the devices. How can I control them from out door? I know I can log onto find.zwave.me from the web browser to control them. How can I do the same function from iphone app? Can you provide me some sample codes?
I know above questions are not related to this thread. I can open a new thread if needed.
