permanently hidden devices in smarthome UI
nic_rt
Post by nic_rt »
Probably a stupid question but I didn't find how to show again the element I previously made "permanently hidden" in the smarthomeUI ! :oops:
Many thanks in advance for your help.
Nick
Raspberry + Razberry + FGS221 x 4 + FGRM 222 + Aeon Labs Micro Motor Controller + FGK 101 + Z-Wave Aeotec Smart Plug-in Switch GEN5 + Minimote + Aeotec KeyFob + Greenwave Smart Power Node x 2
michap
Re: permanently hidden devices in smarthome UI
Post by michap »
"Z-Wave network" -> "Z-Wave devices"
click on "Configuration" of the device where you miss the hidden element
Here you will find the "Hide" and "Unhide" buttons ;)
Hope it helps ;)
Michael
nic_rt
Post by nic_rt »
Many thanks, That's clear but unfortunatly my question was not ! :oops:
In fact I'm trying to recover switches created by "trap events from remotes and sensors" ...
My remote (minimote) doesn't appear in z-way network/z-way devices (it appears only in the expert UI but not in smarthome).
I'm able to check the status like this :
http://rapberry_ip:8083/JS/Run/controller.devices.get("ZWayVDev_zway_Remote_22-0-0").get("permanently_hidden")
The answer is : true
But I didn't find how to change the value to : false ...
Nick
nic_rt
Post by nic_rt »
Done, but probably in the most dirty way :
1 - Stopping the server
2 - Modifying the /z-way-server/htdocs/smarthome/app/js/build.js by replacing line :
if (v.permanently_hidden || v.deviceType == 'battery') {
by
if (v.deviceType == 'battery') {
3 - restarting the server
4 - In smarthome, my hidden switches are now visible. Editing and saving them without changing anything allows to make the permanently_hidden field saved as 'false'.
5 - Doing steps 1 to 3 but setting the line in build.js to its original version (step 2).
I will be happy to know if there is another possibility. The trap is that when a switch created by "trap event from remotes..." is set as permanently hidden, it is then impossible to configure new actions with it as it is invisible everywhere.
Nick
nic_rt
Post by nic_rt »
Probably a bad idea. Restarting the server, all devices are visible and now impossible to hide again (all devices) ....
Nick
You were almost there:
http://rapberry_ip:8083/JS/Run/controller.devices.get("ZWayVDev_zway_Remote_22-0-0").set("permanently_hidden", false)
Or stop the server and edit automation/sotrage/configjson-xxxx.json (find this device and permanently_hidden attribute)
vvuu
Post by vvuu »
didn't work - tell me:
TypeError: Cannot read property 'set' of null
