So very lost...
Posted: 17 Nov 2015 09:21
I think perhaps something is a miss...
I would like to say there is NO clear path from start to finish with this and I really wish there were. There CAN BE!
In the below I am going to start by observing a handful of oversights. This does not mean I do not appreciate ALL the work already done. And if given access to the documentation I would be happy to update it to include my noted oversights.
Let me start with the first basic step I took and that was to load the complete image "razberry.img.zip" to a chip from this page...
http://razberry.z-wave.me/index.php?id=24
That conveniently left out the directions on how to load that image from a windows machine. (someone should fix this) Luckily I knew to find this tool and loaded the image..
http://sourceforge.net/projects/win32diskimager
THAT DOES NOT WORK OUT OF THE BOX. (:
I had to go into the /opt folder and create a symlink from "z-way-server_2015-11-16-09-13-35" to "z-way-server" because the service control script is pointed wrong. (Someone should fix that in the documentation)
I of course could not even log into the machine till I researched the default login information pi/raspberry for the OS/Image (someone should document that) in the directions.
Okay so now I am finally able to access the web interface on port 8083
The directions really do not give me any clarity on this. It would be nice if they pointed you to a page that talks you thorough how to add your first device and first switch and connect them.
I missed the last step to do the manual upgrade.. This happened because you have it sectioned out and I *thought* that upgrading was for people that were not just installing and I thought it self upgraded as part of the install.
And then after there is no clear path...
My question is.. I have managed on my own to figure out how to install a device and as well my remote control (but it does not seem to show up anywhere). I cannot understand how to make the remote control turn on the light. And the directions just END. I did read other manuals but nothing seems clear as to how to do this.
~ Merlin
~ Merlin
