Help needed chaining two lights together
bshure
Post by bshure »
Friends:
Our back yard has a light controlled by a switch outside. There are switches inside to turn on other lights in the back yard.
I want to be able to press the inside switch and have both lights turn on and off like there were on the same switch.
I have tried several apps without success.
Device-and-Elements-Association works great from the Z-way GUI, but not from pressing the wall switch.
If-Then and Logical Rule doesn't work from the switch either.
I did manage to make both lights stay on all the time and I had to unenroll the "trigger" light and re-enroll if.
If I knew javascript I could probably write my own code to do this.
Thanks,
Bert
