Raspberry Pi / Aeon Labs Z-Stick Generation 5
Posted: 24 Nov 2015 19:04
I'm trying to get the z-wave.me software working with a Raspberry Pi with the Aeon Labs Gen 5 USB Stick, but seem failing.
What i did so far is the following:
Plugged the USB STick into the Pi, this results in the following messages in kernel.log:
Once this was done I installed the software:
created a link for ttyAMA0 to ttyACM0:
and added root to the dialout group:
between all these steps (plugging it, installing software, creating symlink) I rebooted the pi. Still it is not getting access to my controller as i understand the messages in z-way-server.log:
What am I missing here ? Or isnt this supposed to work with other USB sticks at all ?
Thx,
Max
root@EGDrivewayCamera:/var/log# tail kernel.log
[ 2.205080] usb 1-1.3: new full-speed USB device number 5 using dwc_otg
[ 2.309124] usb 1-1.3: New USB device found, idVendor=0658, idProduct=0200
[ 2.311036] usb 1-1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.300161] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[ 4.898427] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
[ 4.985776] usbcore: registered new interface driver cdc_acm
[ 5.046813] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
root@EGDrivewayCamera:/var/log# lsusb
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 004: ID 7392:7822 Edimax Technology Co., Ltd
Bus 001 Device 005: ID 0658:0200 Sigma Designs, Inc.
root@EGDrivewayCamera:/dev# ln -s /dev/ttyACM0 ttyAMA0
root@EGDrivewayCamera:/dev# ls -altr ttyA*
crw-rw---T 1 root dialout 166, 0 Jan 1 1970 ttyACM0
lrwxrwxrwx 1 root root 12 Nov 24 17:05 ttyAMA0 -> /dev/ttyACM0
root@EGDrivewayCamera:/dev# usermod -a -G dialout root
root@EGDrivewayCamera:/dev# id
uid=0(root) gid=0(root) groups=0(root),20(dialout),1001(indiecity)
[2015-11-24 17:02:13.068] [D] [zway] Opened device: /dev/ttyAMA0
[2015-11-24 17:02:13.069] [D] [zway] Worker thread successfully created
[2015-11-24 17:02:13.071] [D] [zway] Worker thread entry point
[2015-11-24 17:02:13.082] [I] [zway] Adding job: Get controller info and supported function classes
[2015-11-24 17:02:13.082] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2015-11-24 17:02:13.288] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2015-11-24 17:02:13.288] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2015-11-24 17:02:13.494] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2015-11-24 17:02:13.495] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2015-11-24 17:02:13.701] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2015-11-24 17:02:13.702] [W] [zway] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2015-11-24 17:02:13.702] [D] [zway] Job 0x07 (Get controller info and supported function classes): fail
[2015-11-24 17:02:13.702] [C] [zway] Get Serial API Capabilities returned zero.
[2015-11-24 17:02:13.702] [I] [zway] Removing job: Get controller info and supported function classes
[2015-11-24 17:02:13.713] [D] [zway] Worker thread exit point
[2015-11-24 17:02:13.713] [D] [zway] Worker thread successfully finished
[2015-11-24 17:02:13.718] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
[2015-11-24 17:02:13.765] [I] [core] Notification: critical (z-wave): Cannot start Z-Wave binding: Error: Bad data - communication failed
Thx,
Max
