Accidently deleted "ZWave Network Access App"
Gorilla
Post by Gorilla »
I just accidently deleted the "ZWave Network Access App".
After readding it, all ZWave devices are gone in the HA UI. The expert UI gives me an error: "Error handling data from server".
The log shows several errors:
[2015-12-15 00:18:28.841] [C] [zway] Device is not compatible. Terminating...
[2015-12-15 00:18:28.848] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
[2015-12-15 00:22:09.376] [C] [zway] Device is not compatible. Terminating...
[2015-12-15 00:22:09.401] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
[2015-12-15 00:22:19.646] [C] [zway] Device is not compatible. Terminating...
[2015-12-15 00:22:19.666] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
Do I have to reinclude all devices?
Gorilla
Re: Accidently deleted "ZWave Network Access App"
Post by Gorilla »
I have some more information on the log:
015-12-15 09:39:58.904] [D] [zway] Initialization done
[2015-12-15 09:39:58.904] [D] [zway] Job 0x07 (Get controller info and supported function classes): success
[2015-12-15 09:39:58.904] [C] [zway] Device is not compatible. Terminating...
[2015-12-15 09:39:58.904] [I] [zway] Removing job: Get controller info and supported function classes
[2015-12-15 09:39:58.916] [D] [zway] Worker thread exit point
[2015-12-15 09:39:58.917] [D] [zway] Worker thread successfully finished
[2015-12-15 09:39:58.918] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
[2015-12-15 09:39:58.960] [I] [core] Notification: critical (z-wave): Cannot start Z-Wave binding: Error: Bad data - communication failed
I have the 1st gen razberry module, configured as /dev/ttyAMA0
Gorilla
Post by Gorilla »
After some research I found out that a cold restart would fix the problem.
However, all device configurations are lost.
I got a backup, which folders do I have to restore?
Depends what is missing. If Z-Wave data, then config/zddx and (or full config).
