When logging on to Razpberry I lost all devices and defined rooms. http://mydevice:8083, all my installed devices and rooms are gone. When logging on to http://mydevice:8083/expert, I get the error message "Error handling data from server".
I don't have a backup.
I'm wondering if it still possible to recover one of the previous configurations. Where in the Linux file system can the config be found? Is there any snapshots created when configuration is changed?
I hope someone can help, thank you in advance!
How to restore configuration
Re: How to restore configuration
this mesage is coming up if you are not logged in - or if the UZB stick / Razberry is not found (binded).
Maybe you made any configuration changes at Raspberry?
Check the /var/log/z-way-server.log while starting the Z-Way service, here you can find more information.
Configuration about your Z-Wave network is stored in the Stick / Razberry.
Michael
Michael
