Need help creating associations
Posted: 03 Jan 2016 20:46
I'm (still) pretty new to the z-wave business, so please help me with some very basic information:
I'm using the razberry v2.2.0 GUI and have two PAN04 switch/relay modules. One module (#10 in my case) is connected to a wall switch, the second (#11 in my case) has a lamp attached. To start, I'd like to turn the light on and off as soon as the switch is pressed. I have managed to achieve that with two If-Then-apps, one "if the switch is off, then turn the light off", and one "if the switch is on, then turn the light on". This works, but there is a 3 second delay between the switch being pressed and the light turning on. This delay is not there when I toggle the relay in #11 directly through the GUI, so I suspect it comes from the If-Then-logic, not from the z-wave transmission itself.
I have understood that there are so-called association groups where one device (switch on #10) speaks directly to the relay (#11), bypassing the z-wave controller on the razberry. I have not found how I can establish such an association and would like to ask you for help. (Ideally, please, an idiot-proof step-by-step instruction - I still find the GUI pretty unintuitive...)
(Note: The next question I'll need to solve is how to create an association between the switch and multiple relays, so that toggling the switch turns the lights on different modules on and off. If you care to answer that question as well, I'll be a very happy camper
Thank you so much for your time and assistance,
Thomas
Thomas
