Does RazBerry See Level Changes?
Posted: 06 Jan 2016 05:13
by markolbert
I'm beginning to wonder if the RazBerry, by default, even sees level changes (i.e., when a switch goes from on to off, or off to on, or a dimmer changes level).
I say this because I've been watching the /var/log/z-way-server.log, and it doesn't record anything when I click any of several switches, all of which are known to the z-way-server.
However, the log does reflect activity when the RazBerry API is used to change a level. But that's just a matter of recording an action the server is taking. It's not responding to an event occurring elsewhere in the system.
Now, this lack of recognizing level changes involves GE/Jasco and Linear switches, which may not have the capability of pinging the server/controller with level change events. But some of those switches are supposed to send an event that "something has changed", and I don't see those either.
Has anyone had success seeing level changes, or any kind of status change event, appear in the z-way server logs when a GE/Jasco or Linear switch is tripped?
Re: Does RazBerry See Level Changes?
Posted: 07 Jan 2016 03:20
Means your switches do not report instantly the value to controller nor sends Set commands. Yes, this is the cae for many US devices due to Lutron patent. Controllers are not to blame. Blame Lutron for a stupid patent ;)
The workaround you mention is to send Hail (something has changed). Z-Way should trpa it if it is sent.
Posted: 07 Jan 2016 03:27
by markolbert
Thanx! That explains a lot of what I'm seeing.
I've read online that newer GE/Jasco switches do send a "hail" event to the controller. How do I pick that up within zway? I've been playing around with trapping all the events (via controller.onAny in main.js) but I'm not seeing anything when I manually change the switches. Either my switches don't send a "hail", or I'm not looking in the right place in the zway server.
Posted: 07 Jan 2016 03:39
by markolbert
PoltoS,
In doing some more work here I'm coming to the conclusion that my switches simply don't send any kind of "hey! something has changed!" event to the controller.
In addition to the onAny approach I mentioned earlier, I also added this to main.js:
    var testcallback = function(type, arg) {
        console.log('in testcallback');
    controller.on('ZWave.register', function(regName) {
        console.log('caught ZWave.register event');
        if( regName == 'zway' ) {
            for( var x in zway.devices ) {
                console.log('ZWave.register ' + x);
                if( x != 1 ) {
                    zway.devices[x].data.bind(testcallback, null, true);
                    console.log('bound device ' + x + ' to testcallback()');
        else console.log('ZWave.register regName is ' + regName);
testcallback() gets called a bunch of times during system startup, but it doesn't get called when I turn lights on and off.
Do you think I'm correct in my theory that my switches simply don't report changes to the controller?
If so, are there any other ways of telling switch status other than polling? I can do polling -- I don't need real time awareness of switch state -- but I'd rather avoid it if I can.
Posted: 07 Jan 2016 05:24
If you see nothing in logs on switching, they just send nothing. Make sure to have RaZberry (#1) in all assoc groups of these devices.
Posted: 07 Jan 2016 05:28
by markolbert
I wasn't aware of the assoc group angle. Is that done through the expert UI configuration page for each device?
Posted: 07 Jan 2016 05:32
yes
Posted: 07 Jan 2016 21:25
by markolbert
I checked, and only one of my switches offers an association group. On all the other ones that tab comes up with this message:
Can not configure associations: groups were not reported by the device. Do interview.
But when I do an interview nothing changes. I suspect that's because the hardware doesn't offer association services.
Is there another place to ensure all the switches are part of the controller's association group?
Posted: 18 Jan 2016 13:21
by pz1
PoltoS wrote:If you see nothing in logs on switching, they just send nothing. Make sure to have RaZberry (#1) in all assoc groups of these devices.
My Duewi Wall plugin does send Hail events, but unfortunately it says:
Interview report says it is OK (and it does report Hail)
