I've configured the app BindDevices to trap Aeon Multisensor 6 (gen 5) Tampering event. In the If-dropdown field I see 3 different sensors from the same device - "Sensor General purpose" and two "Alarm Burglar". I chose the Alarm Burglar that I know is the Tampering (Alarm Burglar 2-0-113-7-3) and just configure a device in the Then-field. Now I see in the logs that it's triggered by both Alarm Burglar devices, i.e. not just the tampering - "Alarm Burglar 2-0-113-7-3 Aeon Labs" (tampering) "Alarm Burglar 2-0-113-7-8 Aeon Labs" (motion detection).
I've modified the BindDevice by just adding a trace to be sure that the correct device triggeres the app:
console.log("---- ML ---- sDev.id <" + sDev.get('id') + ">");
console.log("---- ML ---- vDev.id <" + vDev.get('id') + ">");
[2016-01-10 12:41:38.146] [D] [zway] RECEIVED: ( 01 08 00 04 00 02 02 98 40 2B )
[2016-01-10 12:41:38.147] [D] [zway] SENT ACK
[2016-01-10 12:41:38.147] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2016-01-10 12:41:38.147] [I] [zway] Node 2:0 CC Security: sending Nonce Report
[2016-01-10 12:41:38.147] [I] [zway] Adding job: Nonce Report
[2016-01-10 12:41:38.147] [D] [zway] SENDING (cb 0xde): ( 01 11 00 13 02 0A 98 80 15 93 AB 86 AC 31 C1 25 05 DE E4 )
[2016-01-10 12:41:38.156] [D] [zway] RECEIVED ACK
[2016-01-10 12:41:38.156] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-01-10 12:41:38.156] [D] [zway] SENT ACK
[2016-01-10 12:41:38.156] [D] [zway] Delivered to Z-Wave stack
[2016-01-10 12:41:38.177] [D] [zway] RECEIVED: ( 01 07 00 13 DE 00 00 02 37 )
[2016-01-10 12:41:38.177] [D] [zway] SENT ACK
[2016-01-10 12:41:38.177] [I] [zway] Job 0x13 (Nonce Report): Delivered
[2016-01-10 12:41:38.178] [D] [zway] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2016-01-10 12:41:38.178] [D] [zway] SETDATA devices.2.data.lastPacketInfo.packetLength = 13 (0x0000000d)
[2016-01-10 12:41:38.178] [D] [zway] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 21 (0x00000015)
[2016-01-10 12:41:38.178] [D] [zway] SETDATA devices.2.data.lastPacketInfo = **********
[2016-01-10 12:41:38.178] [D] [zway] SendData Response with callback 0xde received: received by recipient
[2016-01-10 12:41:38.178] [D] [zway] SETDATA devices.2.data.lastSend = 1080060 (0x00107afc)
[2016-01-10 12:41:38.179] [D] [zway] Job 0x13 (Nonce Report): success
[2016-01-10 12:41:38.179] [I] [zway] Removing job: Nonce Report
[2016-01-10 12:41:38.188] [D] [zway] RECEIVED: ( 01 1D 00 04 00 02 17 98 81 06 BF 08 04 9F BB 00 2D 53 3C 41 56 15 56 A1 E7 4C D7 3F 72 88 75 )
[2016-01-10 12:41:38.189] [D] [zway] SENT ACK
[2016-01-10 12:41:38.189] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2016-01-10 12:41:38.189] [I] [zway] Node 2:0 CC Security: Received a secure message
[2016-01-10 12:41:38.189] [D] [zway] SETDATA devices.2.instances.0.commandClasses.152.data.firstPart = **********
[2016-01-10 12:41:38.189] [I] [zway] Node 2:0 CC Security: passing decrypted packet to application level: [ 20 01 ff ]
[2016-01-10 12:41:38.189] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcNodeId = 2 (0x00000002)
[2016-01-10 12:41:38.189] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcInstanceId = 0 (0x00000000)
[2016-01-10 12:41:38.190] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.level = 255 (0x000000ff)
[2016-01-10 12:41:38.491] [D] [zway] RECEIVED: ( 01 08 00 04 00 02 02 98 40 2B )
[2016-01-10 12:41:38.492] [D] [zway] SENT ACK
[2016-01-10 12:41:38.492] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2016-01-10 12:41:38.492] [I] [zway] Node 2:0 CC Security: sending Nonce Report
[2016-01-10 12:41:38.492] [I] [zway] Adding job: Nonce Report
[2016-01-10 12:41:38.493] [D] [zway] SENDING (cb 0xdf): ( 01 11 00 13 02 0A 98 80 C1 AC 3A A4 69 AF 33 08 05 DF 39 )
[2016-01-10 12:41:38.501] [D] [zway] RECEIVED ACK
[2016-01-10 12:41:38.501] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-01-10 12:41:38.501] [D] [zway] SENT ACK
[2016-01-10 12:41:38.501] [D] [zway] Delivered to Z-Wave stack
[2016-01-10 12:41:38.522] [D] [zway] RECEIVED: ( 01 07 00 13 DF 00 00 01 35 )
[2016-01-10 12:41:38.522] [D] [zway] SENT ACK
[2016-01-10 12:41:38.522] [I] [zway] Job 0x13 (Nonce Report): Delivered
[2016-01-10 12:41:38.523] [D] [zway] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2016-01-10 12:41:38.523] [D] [zway] SETDATA devices.2.data.lastPacketInfo.packetLength = 13 (0x0000000d)
[2016-01-10 12:41:38.523] [D] [zway] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 21 (0x00000015)
[2016-01-10 12:41:38.523] [D] [zway] SETDATA devices.2.data.lastPacketInfo = **********
[2016-01-10 12:41:38.523] [D] [zway] SendData Response with callback 0xdf received: received by recipient
[2016-01-10 12:41:38.523] [D] [zway] SETDATA devices.2.data.lastSend = 1080094 (0x00107b1e)
[2016-01-10 12:41:38.523] [D] [zway] Job 0x13 (Nonce Report): success
[2016-01-10 12:41:38.524] [I] [zway] Removing job: Nonce Report
[2016-01-10 12:41:38.542] [D] [zway] RECEIVED: ( 01 24 00 04 00 02 1E 98 81 4F F3 5E 19 DF A0 28 1A 9D 6C B6 15 7F 1F 30 5E CD 98 37 C1 94 36 1F B5 2A 55 0B A2 4D )
[2016-01-10 12:41:38.542] [D] [zway] SENT ACK
[2016-01-10 12:41:38.542] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2016-01-10 12:41:38.542] [I] [zway] Node 2:0 CC Security: Received a secure message
[2016-01-10 12:41:38.543] [D] [zway] SETDATA devices.2.instances.0.commandClasses.152.data.firstPart = **********
[2016-01-10 12:41:38.543] [I] [zway] Node 2:0 CC Security: passing decrypted packet to application level: [ 71 05 00 00 00 ff 07 08 00 00 ]
[2016-01-10 12:41:38.543] [D] [zway] SETDATA devices.2.instances.0.commandClasses.113.data.7.eventParameters = byte[0]
[2016-01-10 12:41:38.543] [D] [zway] ( zero-length buffer )
[2016-01-10 12:41:38.543] [D] [zway] SETDATA devices.2.instances.0.commandClasses.113.data.7.event = 8 (0x00000008)
[2016-01-10 12:41:38.545] [D] [zway] SETDATA devices.2.instances.0.commandClasses.113.data.7.eventString = ""
[2016-01-10 12:41:38.545] [D] [zway] SETDATA devices.2.instances.0.commandClasses.113.data.7.status = 255 (0x000000ff)
[2016-01-10 12:41:38.546] [D] [zway] SETDATA devices.2.instances.0.commandClasses.113.data.7 = Empty
[2016-01-10 12:41:38.562] [I] [core] Notification: device-info (device-OnOff): {"dev":"Alarm Burglar 2-0-113-7-8 Aeon Labs","l":"on"}
[2016-01-10 12:41:58.458] [D] [zway] Job 0x13: deleted from queue
[2016-01-10 12:41:58.763] [D] [zway] Job 0x13: deleted from queue
[2016-01-10 12:43:31.162] [D] [zway] RECEIVED: ( 01 08 00 04 00 02 02 84 07 70 )
[2016-01-10 12:43:31.162] [D] [zway] SENT ACK
[2016-01-10 12:43:31.162] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2016-01-10 12:43:31.162] [I] [zway] Node 2:0 CC Wakeup: Wakeup notification
[2016-01-10 12:43:31.162] [D] [zway] SETDATA devices.2.instances.0.commandClasses.132.data.lastWakeup = 1452426211 (0x569243e3)
[2016-01-10 12:43:31.162] [D] [zway] SETDATA devices.2.data.lastSend = 1091188 (0x0010a674)
[2016-01-10 12:43:31.163] [D] [zway] SETDATA devices.2.data.lastNonceGet = 1090188 (0x0010a28c)
[2016-01-10 12:43:31.163] [D] [zway] Running wakeup handler for node 2
[2016-01-10 12:43:31.163] [D] [zway] SETDATA devices.2.instances.0.commandClasses.132.data.lastSleep = 1452426211 (0x569243e3)
[2016-01-10 12:43:31.163] [I] [zway] Node 2:0 CC Wakeup: Send node to sleep
[2016-01-10 12:43:31.163] [I] [zway] Adding job: Wakeup Sleep
[2016-01-10 12:43:31.234] [D] [zway] SENDING (cb 0xcf): ( 01 09 00 13 02 02 98 40 05 CF F7 )
[2016-01-10 12:43:31.235] [D] [zway] RECEIVED ACK
[2016-01-10 12:43:31.239] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-01-10 12:43:31.239] [D] [zway] SENT ACK
[2016-01-10 12:43:31.239] [D] [zway] Delivered to Z-Wave stack
[2016-01-10 12:43:31.255] [D] [zway] RECEIVED: ( 01 07 00 13 CF 00 00 01 25 )
[2016-01-10 12:43:31.255] [D] [zway] SENT ACK
[2016-01-10 12:43:31.255] [I] [zway] Job 0x13 (Nonce Get): Delivered
[2016-01-10 12:43:31.255] [D] [zway] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2016-01-10 12:43:31.255] [D] [zway] SETDATA devices.2.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2016-01-10 12:43:31.256] [D] [zway] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 15 (0x0000000f)
[2016-01-10 12:43:31.256] [D] [zway] SETDATA devices.2.data.lastPacketInfo = **********
[2016-01-10 12:43:31.256] [D] [zway] SendData Response with callback 0xcf received: received by recipient
[2016-01-10 12:43:31.256] [D] [zway] SETDATA devices.2.data.lastSend = 1091197 (0x0010a67d)
[2016-01-10 12:43:31.256] [D] [zway] Job 0x13 (Nonce Get): success
[2016-01-10 12:43:31.256] [D] [zway] SETDATA devices.2.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2016-01-10 12:43:31.256] [I] [zway] Removing job: Nonce Get
[2016-01-10 12:43:31.257] [I] [zway] Node 2:0 CC Security: sending Nonce Get
[2016-01-10 12:43:31.257] [D] [zway] SETDATA devices.2.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2016-01-10 12:43:31.257] [I] [zway] Job 0x13 (Wakeup Sleep): Cancelling job: Wakeup Sleep
[2016-01-10 12:43:31.257] [I] [zway] Removing job: Wakeup Sleep
[2016-01-10 12:43:31.257] [I] [zway] Adding job: Nonce Get
[2016-01-10 12:43:31.257] [D] [zway] SETDATA devices.2.instances.0.commandClasses.132.data.lastSleep = 1452426211 (0x569243e3)
[2016-01-10 12:43:31.257] [I] [zway] Node 2:0 CC Wakeup: Send node to sleep
[2016-01-10 12:43:31.257] [I] [zway] Adding job: Wakeup Sleep
[2016-01-10 12:43:31.257] [D] [zway] SETDATA devices.2.data.lastNonceGet = 1091197 (0x0010a67d)
[2016-01-10 12:43:31.275] [D] [zway] RECEIVED: ( 01 10 00 04 00 02 0A 98 80 17 67 E0 59 0A 88 AB 75 6E )
[2016-01-10 12:43:31.275] [D] [zway] SENT ACK
[2016-01-10 12:43:31.275] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2016-01-10 12:43:31.275] [I] [zway] Node 2:0 CC Security: received Nonce Report
[2016-01-10 12:43:31.275] [W] [zway] Node 2:0 CC Security: Nonce Get was not ACKed yet. Ignoring this nonce
[2016-01-10 12:43:31.326] [D] [zway] SENDING (cb 0xe0): ( 01 09 00 13 02 02 98 40 05 E0 D8 )
[2016-01-10 12:43:31.327] [D] [zway] RECEIVED ACK
[2016-01-10 12:43:31.331] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-01-10 12:43:31.332] [D] [zway] SENT ACK
[2016-01-10 12:43:31.332] [D] [zway] Delivered to Z-Wave stack
[2016-01-10 12:43:31.346] [D] [zway] RECEIVED: ( 01 07 00 13 E0 00 00 02 09 )
[2016-01-10 12:43:31.346] [D] [zway] SENT ACK
[2016-01-10 12:43:31.346] [I] [zway] Job 0x13 (Nonce Get): Delivered
[2016-01-10 12:43:31.346] [D] [zway] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2016-01-10 12:43:31.347] [D] [zway] SETDATA devices.2.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2016-01-10 12:43:31.347] [D] [zway] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 14 (0x0000000e)
[2016-01-10 12:43:31.347] [D] [zway] SETDATA devices.2.data.lastPacketInfo = **********
[2016-01-10 12:43:31.347] [D] [zway] SendData Response with callback 0xe0 received: received by recipient
[2016-01-10 12:43:31.347] [D] [zway] SETDATA devices.2.data.lastSend = 1091206 (0x0010a686)
[2016-01-10 12:43:31.348] [D] [zway] Job 0x13 (Nonce Get): success
[2016-01-10 12:43:31.348] [D] [zway] SETDATA devices.2.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2016-01-10 12:43:31.348] [I] [zway] Removing job: Nonce Get
[2016-01-10 12:43:31.417] [D] [zway] SENDING (cb 0xe1): ( 01 09 00 13 02 02 84 08 05 E1 8D )
[2016-01-10 12:43:31.419] [D] [zway] RECEIVED ACK
[2016-01-10 12:43:31.423] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-01-10 12:43:31.423] [D] [zway] SENT ACK
[2016-01-10 12:43:31.423] [D] [zway] Delivered to Z-Wave stack
[2016-01-10 12:43:31.438] [D] [zway] RECEIVED: ( 01 07 00 13 E1 00 00 02 08 )
[2016-01-10 12:43:31.439] [D] [zway] SENT ACK
[2016-01-10 12:43:31.439] [I] [zway] Job 0x13 (Wakeup Sleep): Delivered
[2016-01-10 12:43:31.439] [D] [zway] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2016-01-10 12:43:31.439] [D] [zway] SETDATA devices.2.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2016-01-10 12:43:31.439] [D] [zway] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 15 (0x0000000f)
[2016-01-10 12:43:31.439] [D] [zway] SETDATA devices.2.data.lastPacketInfo = **********
[2016-01-10 12:43:31.440] [D] [zway] SendData Response with callback 0xe1 received: received by recipient
[2016-01-10 12:43:31.440] [D] [zway] SETDATA devices.2.data.lastSend = 1091215 (0x0010a68f)
[2016-01-10 12:43:31.440] [D] [zway] Job 0x13 (Wakeup Sleep): success
[2016-01-10 12:43:31.440] [D] [zway] SETDATA devices.2.data.isAwake = False
[2016-01-10 12:43:31.440] [D] [zway] Sending the queue for node 2 into sleep
[2016-01-10 12:43:31.440] [I] [zway] Removing job: Wakeup Sleep
[2016-01-10 12:43:31.489] [D] [zway] RECEIVED: ( 01 10 00 04 00 02 0A 98 80 CB B2 8F 01 03 0E 34 55 60 )
[2016-01-10 12:43:31.489] [D] [zway] SENT ACK
[2016-01-10 12:43:31.489] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2016-01-10 12:43:31.489] [I] [zway] Node 2:0 CC Security: received Nonce Report
[2016-01-10 12:43:31.489] [D] [zway] SETDATA devices.2.instances.0.commandClasses.152.data.rNonce = **********
[2016-01-10 12:43:51.524] [D] [zway] Job 0x13: deleted from queue
[2016-01-10 12:43:51.585] [D] [zway] Job 0x13: deleted from queue
[2016-01-10 12:43:51.666] [D] [zway] Job 0x13: deleted from queue
[2016-01-10 12:44:44.351] [D] [zway] RECEIVED: ( 01 08 00 04 00 04 02 84 07 76 )
[2016-01-10 12:44:44.351] [D] [zway] SENT ACK
[2016-01-10 12:44:44.352] [D] [zway] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2016-01-10 12:44:44.352] [I] [zway] Node 4:0 CC Wakeup: Wakeup notification
[2016-01-10 12:44:44.352] [D] [zway] SETDATA devices.4.instances.0.commandClasses.132.data.lastWakeup = 1452426284 (0x5692442c)
[2016-01-10 12:44:44.352] [D] [zway] SETDATA devices.4.data.isAwake = True
[2016-01-10 12:44:44.352] [D] [zway] SETDATA devices.4.data.lastSend = 1098405 (0x0010c2a5)
[2016-01-10 12:44:44.352] [D] [zway] SETDATA devices.4.data.lastNonceGet = 1097405 (0x0010bebd)
[2016-01-10 12:44:44.352] [D] [zway] Running wakeup handler for node 4
[2016-01-10 12:44:44.352] [D] [zway] SETDATA devices.4.instances.0.commandClasses.132.data.lastSleep = 1452426284 (0x5692442c)
[2016-01-10 12:44:44.353] [I] [zway] Node 4:0 CC Wakeup: Send node to sleep
[2016-01-10 12:44:44.353] [I] [zway] Adding job: Wakeup Sleep
[2016-01-10 12:44:44.422] [D] [zway] SENDING (cb 0xdd): ( 01 09 00 13 04 02 98 40 05 DD E3 )
[2016-01-10 12:44:44.424] [D] [zway] RECEIVED ACK
[2016-01-10 12:44:44.428] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-01-10 12:44:44.428] [D] [zway] SENT ACK
[2016-01-10 12:44:44.428] [D] [zway] Delivered to Z-Wave stack
[2016-01-10 12:44:44.443] [D] [zway] RECEIVED: ( 01 07 00 13 DD 00 00 01 37 )
[2016-01-10 12:44:44.443] [D] [zway] SENT ACK
[2016-01-10 12:44:44.443] [I] [zway] Job 0x13 (Nonce Get): Delivered
[2016-01-10 12:44:44.443] [D] [zway] SETDATA devices.4.data.lastPacketInfo.delivered = True
[2016-01-10 12:44:44.443] [D] [zway] SETDATA devices.4.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2016-01-10 12:44:44.443] [D] [zway] SETDATA devices.4.data.lastPacketInfo.deliveryTime = 14 (0x0000000e)
[2016-01-10 12:44:44.444] [D] [zway] SETDATA devices.4.data.lastPacketInfo = **********
[2016-01-10 12:44:44.444] [D] [zway] SendData Response with callback 0xdd received: received by recipient
[2016-01-10 12:44:44.444] [D] [zway] SETDATA devices.4.data.lastSend = 1098414 (0x0010c2ae)
[2016-01-10 12:44:44.444] [D] [zway] Job 0x13 (Nonce Get): success
[2016-01-10 12:44:44.444] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2016-01-10 12:44:44.444] [I] [zway] Removing job: Nonce Get
[2016-01-10 12:44:44.444] [I] [zway] Node 4:0 CC Security: sending Nonce Get
[2016-01-10 12:44:44.445] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2016-01-10 12:44:44.445] [I] [zway] Job 0x13 (Wakeup Sleep): Cancelling job: Wakeup Sleep
[2016-01-10 12:44:44.445] [I] [zway] Removing job: Wakeup Sleep
[2016-01-10 12:44:44.445] [I] [zway] Adding job: Nonce Get
[2016-01-10 12:44:44.445] [D] [zway] SETDATA devices.4.instances.0.commandClasses.132.data.lastSleep = 1452426284 (0x5692442c)
[2016-01-10 12:44:44.445] [I] [zway] Node 4:0 CC Wakeup: Send node to sleep
[2016-01-10 12:44:44.445] [I] [zway] Adding job: Wakeup Sleep
[2016-01-10 12:44:44.445] [D] [zway] SETDATA devices.4.data.lastNonceGet = 1098414 (0x0010c2ae)
[2016-01-10 12:44:44.464] [D] [zway] RECEIVED: ( 01 10 00 04 00 04 0A 98 80 53 32 80 CA D1 8E 57 8F 51 )
[2016-01-10 12:44:44.464] [D] [zway] SENT ACK
[2016-01-10 12:44:44.464] [D] [zway] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2016-01-10 12:44:44.464] [I] [zway] Node 4:0 CC Security: received Nonce Report
[2016-01-10 12:44:44.465] [W] [zway] Node 4:0 CC Security: Nonce Get was not ACKed yet. Ignoring this nonce
[2016-01-10 12:44:44.518] [D] [zway] SENDING (cb 0xe2): ( 01 09 00 13 04 02 98 40 05 E2 DC )
[2016-01-10 12:44:44.520] [D] [zway] RECEIVED ACK
[2016-01-10 12:44:44.524] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-01-10 12:44:44.524] [D] [zway] SENT ACK
[2016-01-10 12:44:44.524] [D] [zway] Delivered to Z-Wave stack
[2016-01-10 12:44:44.540] [D] [zway] RECEIVED: ( 01 07 00 13 E2 00 00 02 0B )
[2016-01-10 12:44:44.540] [D] [zway] SENT ACK
[2016-01-10 12:44:44.540] [I] [zway] Job 0x13 (Nonce Get): Delivered
[2016-01-10 12:44:44.540] [D] [zway] SETDATA devices.4.data.lastPacketInfo.delivered = True
[2016-01-10 12:44:44.540] [D] [zway] SETDATA devices.4.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2016-01-10 12:44:44.540] [D] [zway] SETDATA devices.4.data.lastPacketInfo.deliveryTime = 15 (0x0000000f)
[2016-01-10 12:44:44.541] [D] [zway] SETDATA devices.4.data.lastPacketInfo = **********
[2016-01-10 12:44:44.541] [D] [zway] SendData Response with callback 0xe2 received: received by recipient
[2016-01-10 12:44:44.541] [D] [zway] SETDATA devices.4.data.lastSend = 1098423 (0x0010c2b7)
[2016-01-10 12:44:44.541] [D] [zway] Job 0x13 (Nonce Get): success
[2016-01-10 12:44:44.541] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2016-01-10 12:44:44.541] [I] [zway] Removing job: Nonce Get
[2016-01-10 12:44:44.612] [D] [zway] SENDING (cb 0xe3): ( 01 09 00 13 04 02 84 08 05 E3 89 )
[2016-01-10 12:44:44.614] [D] [zway] RECEIVED ACK
[2016-01-10 12:44:44.617] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-01-10 12:44:44.617] [D] [zway] SENT ACK
[2016-01-10 12:44:44.618] [D] [zway] Delivered to Z-Wave stack
[2016-01-10 12:44:44.632] [D] [zway] RECEIVED: ( 01 07 00 13 E3 00 00 01 09 )
[2016-01-10 12:44:44.632] [D] [zway] SENT ACK
[2016-01-10 12:44:44.633] [I] [zway] Job 0x13 (Wakeup Sleep): Delivered
[2016-01-10 12:44:44.633] [D] [zway] SETDATA devices.4.data.lastPacketInfo.delivered = True
[2016-01-10 12:44:44.633] [D] [zway] SETDATA devices.4.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2016-01-10 12:44:44.633] [D] [zway] SETDATA devices.4.data.lastPacketInfo.deliveryTime = 14 (0x0000000e)
[2016-01-10 12:44:44.633] [D] [zway] SETDATA devices.4.data.lastPacketInfo = **********
[2016-01-10 12:44:44.633] [D] [zway] SendData Response with callback 0xe3 received: received by recipient
[2016-01-10 12:44:44.633] [D] [zway] SETDATA devices.4.data.lastSend = 1098432 (0x0010c2c0)
[2016-01-10 12:44:44.634] [D] [zway] Job 0x13 (Wakeup Sleep): success
[2016-01-10 12:44:44.634] [D] [zway] SETDATA devices.4.data.isAwake = False
[2016-01-10 12:44:44.634] [D] [zway] Sending the queue for node 4 into sleep
[2016-01-10 12:44:44.634] [I] [zway] Removing job: Wakeup Sleep
[2016-01-10 12:44:44.674] [D] [zway] RECEIVED: ( 01 10 00 04 00 04 0A 98 80 11 05 2B EF 25 5A 32 28 48 )
[2016-01-10 12:44:44.674] [D] [zway] SENT ACK
[2016-01-10 12:44:44.674] [D] [zway] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2016-01-10 12:44:44.674] [I] [zway] Node 4:0 CC Security: received Nonce Report
[2016-01-10 12:44:44.674] [D] [zway] SETDATA devices.4.instances.0.commandClasses.152.data.rNonce = **********
[2016-01-10 12:45:04.694] [D] [zway] Job 0x13: deleted from queue
[2016-01-10 12:45:04.755] [D] [zway] Job 0x13: deleted from queue
[2016-01-10 12:45:04.836] [D] [zway] Job 0x13: deleted from queue
[2016-01-10 12:45:38.683] [D] [zway] RECEIVED: ( 01 08 00 04 00 02 02 98 40 2B )
[2016-01-10 12:45:38.684] [D] [zway] SENT ACK
[2016-01-10 12:45:38.684] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2016-01-10 12:45:38.684] [I] [zway] Node 2:0 CC Security: sending Nonce Report
[2016-01-10 12:45:38.684] [D] [zway] SETDATA devices.2.data.isAwake = True
[2016-01-10 12:45:38.684] [I] [zway] Adding job: Nonce Report
[2016-01-10 12:45:38.685] [D] [zway] SENDING (cb 0xe4): ( 01 11 00 13 02 0A 98 80 3D 89 0C 0C 34 37 03 0B 05 E4 B3 )
[2016-01-10 12:45:38.693] [D] [zway] RECEIVED ACK
[2016-01-10 12:45:38.693] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-01-10 12:45:38.693] [D] [zway] SENT ACK
[2016-01-10 12:45:38.693] [D] [zway] Delivered to Z-Wave stack
[2016-01-10 12:45:38.713] [D] [zway] RECEIVED: ( 01 07 00 13 E4 00 00 02 0D )
[2016-01-10 12:45:38.713] [D] [zway] SENT ACK
[2016-01-10 12:45:38.714] [I] [zway] Job 0x13 (Nonce Report): Delivered
[2016-01-10 12:45:38.714] [D] [zway] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2016-01-10 12:45:38.714] [D] [zway] SETDATA devices.2.data.lastPacketInfo.packetLength = 13 (0x0000000d)
[2016-01-10 12:45:38.714] [D] [zway] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 20 (0x00000014)
[2016-01-10 12:45:38.714] [D] [zway] SETDATA devices.2.data.lastPacketInfo = **********
[2016-01-10 12:45:38.714] [D] [zway] SendData Response with callback 0xe4 received: received by recipient
[2016-01-10 12:45:38.715] [D] [zway] SETDATA devices.2.data.lastSend = 1103764 (0x0010d794)
[2016-01-10 12:45:38.715] [D] [zway] Job 0x13 (Nonce Report): success
[2016-01-10 12:45:38.715] [I] [zway] Removing job: Nonce Report
[2016-01-10 12:45:38.724] [D] [zway] RECEIVED: ( 01 1D 00 04 00 02 17 98 81 79 AE 9D 6E CA E2 19 68 35 E3 4A 98 3D D9 87 67 75 F3 AC 49 71 85 )
[2016-01-10 12:45:38.724] [D] [zway] SENT ACK
[2016-01-10 12:45:38.725] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2016-01-10 12:45:38.725] [I] [zway] Node 2:0 CC Security: Received a secure message
[2016-01-10 12:45:38.725] [D] [zway] SETDATA devices.2.instances.0.commandClasses.152.data.firstPart = **********
[2016-01-10 12:45:38.725] [I] [zway] Node 2:0 CC Security: passing decrypted packet to application level: [ 20 01 00 ]
[2016-01-10 12:45:38.725] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcNodeId = 2 (0x00000002)
[2016-01-10 12:45:38.725] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.srcInstanceId = 0 (0x00000000)
[2016-01-10 12:45:38.726] [D] [zway] SETDATA devices.1.instances.0.commandClasses.32.data.level = 0 (0x00000000)
[2016-01-10 12:45:39.037] [D] [zway] RECEIVED: ( 01 08 00 04 00 02 02 98 40 2B )
[2016-01-10 12:45:39.038] [D] [zway] SENT ACK
[2016-01-10 12:45:39.038] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2016-01-10 12:45:39.038] [I] [zway] Node 2:0 CC Security: sending Nonce Report
[2016-01-10 12:45:39.038] [I] [zway] Adding job: Nonce Report
[2016-01-10 12:45:39.039] [D] [zway] SENDING (cb 0xe5): ( 01 11 00 13 02 0A 98 80 35 35 CD 8B 75 83 7B ED 05 E5 2B )
[2016-01-10 12:45:39.047] [D] [zway] RECEIVED ACK
[2016-01-10 12:45:39.047] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-01-10 12:45:39.047] [D] [zway] SENT ACK
[2016-01-10 12:45:39.047] [D] [zway] Delivered to Z-Wave stack
[2016-01-10 12:45:39.068] [D] [zway] RECEIVED: ( 01 07 00 13 E5 00 00 02 0C )
[2016-01-10 12:45:39.068] [D] [zway] SENT ACK
[2016-01-10 12:45:39.068] [I] [zway] Job 0x13 (Nonce Report): Delivered
[2016-01-10 12:45:39.069] [D] [zway] SETDATA devices.2.data.lastPacketInfo.delivered = True
[2016-01-10 12:45:39.069] [D] [zway] SETDATA devices.2.data.lastPacketInfo.packetLength = 13 (0x0000000d)
[2016-01-10 12:45:39.069] [D] [zway] SETDATA devices.2.data.lastPacketInfo.deliveryTime = 21 (0x00000015)
[2016-01-10 12:45:39.069] [D] [zway] SETDATA devices.2.data.lastPacketInfo = **********
[2016-01-10 12:45:39.069] [D] [zway] SendData Response with callback 0xe5 received: received by recipient
[2016-01-10 12:45:39.069] [D] [zway] SETDATA devices.2.data.lastSend = 1103799 (0x0010d7b7)
[2016-01-10 12:45:39.070] [D] [zway] Job 0x13 (Nonce Report): success
[2016-01-10 12:45:39.070] [I] [zway] Removing job: Nonce Report
[2016-01-10 12:45:39.088] [D] [zway] RECEIVED: ( 01 24 00 04 00 02 1E 98 81 10 AD 70 89 C5 A2 BB 3E E1 E9 78 AD 5A E1 D6 BF 5C 53 24 35 F7 C5 94 25 95 6F 3E DD F7 )
[2016-01-10 12:45:39.088] [D] [zway] SENT ACK
[2016-01-10 12:45:39.088] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2016-01-10 12:45:39.088] [I] [zway] Node 2:0 CC Security: Received a secure message
[2016-01-10 12:45:39.088] [D] [zway] SETDATA devices.2.instances.0.commandClasses.152.data.firstPart = **********
[2016-01-10 12:45:39.089] [I] [zway] Node 2:0 CC Security: passing decrypted packet to application level: [ 71 05 00 00 00 ff 07 00 00 00 ]
[2016-01-10 12:45:39.089] [D] [zway] SETDATA devices.2.instances.0.commandClasses.113.data.7.eventParameters = byte[0]
[2016-01-10 12:45:39.089] [D] [zway] ( zero-length buffer )
[2016-01-10 12:45:39.089] [D] [zway] SETDATA devices.2.instances.0.commandClasses.113.data.7.event = 0 (0x00000000)
[2016-01-10 12:45:39.091] [D] [zway] SETDATA devices.2.instances.0.commandClasses.113.data.7.eventString = ""
[2016-01-10 12:45:39.091] [D] [zway] SETDATA devices.2.instances.0.commandClasses.113.data.7.status = 255 (0x000000ff)
[2016-01-10 12:45:39.091] [D] [zway] SETDATA devices.2.instances.0.commandClasses.113.data.7 = Empty
[2016-01-10 12:45:39.162] [I] [core] ---- ML ---- sDev.id <ZWayVDev_zway_2-0-113-7-3-A>
[2016-01-10 12:45:39.164] [I] [core] ---- ML ---- vDev.id <SendMail_14>
[2016-01-10 12:45:39.165] [I] [core] --- SendMail_14 performCommand processing: {"0":"off"}
[2016-01-10 12:45:39.167] [I] [core] ---- ML ---- command is <off> which is going to be set as new level, and deviceType is <switchBinary>
[2016-01-10 12:45:54.363] [I] [core] Notification: device-info (device-OnOff): {"dev":"Alarm Burglar 2-0-113-7-8 Aeon Labs","l":"off"}
Cheers,
Bo
