Problem with Events in Popp Hub
Posted: 10 Jan 2016 18:13
by moremoe
Hi all, first time poster, hope this is int the right place. I bought a Popp Hub recently. I have upgraded the firmware to the latest. What I have a problem with is that I don't see any Events in the Timeline:
- popp2.GIF (64.39 KiB) Viewed 10718 times
I've triggerd my Aeon Water Sensor and that works. It goes form on too off, no problem there. But I don't get a event in the timeline and when I jump over to my sensors and apps all it says is last updated "119 days" or "119 undefined". So I cant se when the last update was:
- popp1.GIF (103.45 KiB) Viewed 10718 times
Am I missing something? Really appreciate some advice. Thanks for reading.
/Marten
Re: Problem with Events in Popp Hub
Posted: 11 Jan 2016 11:02
by Christian12
is the app trap event active?
Posted: 12 Jan 2016 19:26
by moremoe
Christian12 wrote:is the app trap event active?
Yes and I've reinstalled it and done a several reboots.
Posted: 12 Jan 2016 22:15
by moremoe
When I go in to check on a device I have added today it says it was added 17.09.2015.
- popp date.GIF (76.98 KiB) Viewed 10668 times
That might explain why I don't see any sensor data in the timeline?
Posted: 12 Jan 2016 23:20
by Christian12
i have a popp hub, too. But i have installed the razberry image and no pop sign in the corner.
No, when the sensor detect, it will send at the moment it detects water. i think you should install a new image on your sd, my was broken when i received the hub.
You can download it from here:
http://razberry.z-wave.me/z-way-server/razberry.img.zip
