SwitchMultilevel error with 2.2.0
fredolphin
Post by fredolphin »
Since, I am using the version 2.2.0 version of z-way-server, the command class SwitchMultilevel is failing when trying to Set a value. I need to force a new interview on the device in order to make it work again. However, after few days, it is failing again etc ... And It need again to force the interview etc ...
The device is the Qubino Flush Dimmer.
Are you facing this issue as well ? What can we do to fix it definitely without being able to force the interview on a regular basis.
Thank you
Frédéric
viper384
Re: SwitchMultilevel error with 2.2.0
Post by viper384 »
SwitchMultiLevel works on v2.2.0 for me, on my Aspire RF devices. Maybe displaying the contents of /var/log/z-way-server.log when the device is in error will shed some light on your issue? Also check in expert mode when not working.
