upgrade errors
nilew
upgrade errors
Post by nilew »
new to this forum.
Just bought a razberry and started testing some things.
Today i saw there was an update to v2.2.1 available so I started downloading it.
It took forever to get installed and I went to the main page before the status bar was finished.
It seemed to worked.
But now I get all sort of errors.
like when I try to manage it with port 8084 is displays this:
Webif is switched off. You can switch it on from Z-Way UI or box shell
How do I turn it on?
And the app page has diffrent sizes of icons and can't download any app, just gives an error Failed to install the app.
What could be wrong? how can I fix this?
Thanks,
Rickard
Re: upgrade errors
To turn it on go to Settings->management->Firmware update
Plainsane
Re: upgrade errors
Post by Plainsane »
PoltoS wrote:To turn it on go to Settings->management->Firmware update
I went there but I don't see the option to enable webif
remoticz
Re: upgrade errors
Post by remoticz »
@PoltoS, your not serious about that answer are you?
By now, I have upgraded my test system 12 times, and after half a day or so WebIF is unavailable again. Does not seem to be a sensible solution you gaves.
v2.1.1 raspi2
nochkin
Re: upgrade errors
Post by nochkin »
Once you open the firmware update, you will get port 8084 "Webif" opened automatically.
You can either use that "Firmware update" pop-up or open it directly in your browser.
The Webif will be closed automatically after you close "Firmware update" popup.
Are you looking for something specific on port 8084?
