Page 1 of 2
Not able to access Expert UI from Port 8084
Posted: 02 Mar 2016 07:44
by Black Cat
First time poster and trying to get my head around this system.
After I upgraded to V2.2.1 I'm unable to access the Expert UI from Port 8084, all I get is the following message.
Webif is switched off. You can switch it on from Z-Way UI or box shell
I have not been able to find where I can switch it on, can anyone help please?
Re: Not able to access Expert UI from Port 8084
Posted: 02 Mar 2016 17:49
by DomotikQuebec
Log in as admin on port 8083,
Go to your account settings and there is a checkbox to enable the expert UI
Good luck
Posted: 02 Mar 2016 18:20
by pz1
Click the tools icon in the top right corner, select Devices from Dropdown menu and you get the link:
- Expert.PNG (3 KiB) Viewed 22184 times
Posted: 02 Mar 2016 23:15
by Black Cat
Nup,
All I get from the devices menu is:
- Screenshot_1.png (15.57 KiB) Viewed 22166 times
Posted: 03 Mar 2016 00:25
by pz1
What Z-Wave controller do you have? If so do you have the Zwave module enabled on the correct port?
Posted: 04 Mar 2016 23:16
by Black Cat
It's a Popp Hub.
Posted: 05 Mar 2016 11:50
by pz1
Sorry, I don't know that rig. Better send this question to the store where you bought this, or to Popp directly. They are primarily responsible for proper functioning
Posted: 05 Mar 2016 23:14
by Black Cat
That's strange, as this only started after I upgraded to the latest firmware version.
As far as I can see there is no difference in the Popp as it's a RP2 with the Z daughter board!
Posted: 05 Mar 2016 23:19
by pz1
It looks as if your Z-Wave is not properly running. I your Z-Wave app active"? what port?
Posted: 15 Mar 2016 19:11
by DomotikQuebec
OH ! I got the same thing but I didn't got it correctly the first time...
1: This is not the Expert UI but the "mongoose" interface. Expert UI is on port 8083 and the Webif is on 8084 (right ?)
2: I got it event after updating firmware
3: I thought that I may have disabled some app so I reinstall my whole Raspberry + Z-Way but no luck !
