Re: Smart UI - Dimmer Issues
Posted: 01 Oct 2016 00:13
After installing v2.2.4-rc17 (where the v1.5.0 UI is present) I can confirm that the dimmer is finally working. I have tested it on my PC using Firefox v49.0.1 as well as Google Chrome (53.0.2785.116 m (64-bit)) and it is working even if the behavior is slightly strange (see below). I have also tested on a Samsung S7 using both the Samsung bloatware browser as well as Chrome v53.0 all under Android 6.0.1.
The slightly strange behavior is as follows: Assuming the dial is at 20. If I increase the dial to 60, the indicator will jump to 60 when I release the mouse (or finger) and the light will dim up. Now the dial will jump down to some arbitrary value close to 20 and a few seconds later the dial will jump to 60. Correspondingly when dimming down.
I assume this is due to the UI sensing the actual value of the dimmer during transition from one setting to another? With the "soft dim" function of most modern dimmers, the UI probably reads the actual value of the dimmer several times during the dimming process.
This is a small nuisance compared to the previous function in v2.2.3
Thank you!
Thank you!
