HomeSeer dimmers / CentralScene based assosication
i8beef
Post by i8beef »
Hey, just playing with one of these now, and was wondering if anyone knows how to get the central scene based association working with HomeSeer dimmers and ZWay? And if not, is there a way to jack up the polling speed?
i8beef
Re: HomeSeer dimmers / CentralScene based assosication
Post by i8beef »
I'm guessing by the resounding silence, that the answer here is no, this isn't supported right now? I know the central scene based instant status stuff is new, so that's ok if it's the case.
Does anyone then have any idea how I might utilize one of the other modules, or write a module, that will handle this? I'd be happy with "button push triggers poll after three seconds" (to let the dimmer ramp up or down first) if there's no easy way to get the value passed by central scene. I've poked at a few of the modules but I don't see any that would let me trigger a poll like this...
Hello!
One you enable Trap Events module, it will create virtual devices on each event from Central Scene CC. You can then use these virtual devices in your rules.
i8beef
Post by i8beef »
Yes, I have the virtual devices, but what do I then use make it do the following:
1. Wait for 5 seconds
2. Update the device state
I haven't been able to figure out how to do that part.
You can use it in If-Then or LogicalRules module
i8beef
Post by i8beef »
Yes, but like I said, none of the modules I've seen seem to support the next step, which is triggering an update poll after a few seconds. I'm happy to write a module that does that... is there a good place to look to start a new module?
i8beef
Post by i8beef »
Ok, so I realized I was about to pretty much duplicate the If-Then module, so I forked the original and added the functionality there instead. It adds an option for someone to trigger a POLL on the device after a designated delay instead of just setting a static value. Pull request submitted.
Thanks. We will check it and decide if we merge it in trunk or suggest a separate module
jswim788
Post by jswim788 »
Is there any way to distinguish the keyAttribute on the virtual device? I can see that a single, double or triple tap on the dimmer is changing this value, but I can't find a way to use this. The virtual device only seems to get an 'on' message.
[2016-12-10 19:14:14.088] [D] [zway] RECEIVED: ( 01 0B 00 04 00 09 05 5B 03 13 03 01 B5 )
[2016-12-10 19:14:14.088] [D] [zway] SENT ACK
[2016-12-10 19:14:14.088] [D] [zway] SETDATA controller.data.incomingPacket.nodeId = 9 (0x00000009)
[2016-12-10 19:14:14.088] [D] [zway] SETDATA controller.data.incomingPacket.frameType = "singlecast"
[2016-12-10 19:14:14.088] [D] [zway] SETDATA controller.data.incomingPacket = **********
[2016-12-10 19:14:14.088] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2016-12-10 19:14:14.088] [D] [zway] SETDATA devices.9.instances.0.commandClasses.91.data.sequence = **********
[2016-12-10 19:14:14.088] [D] [zway] SETDATA devices.1.instances.0.commandClasses.91.data.srcNodeId = 9 (0x00000009)
[2016-12-10 19:14:14.088] [D] [zway] SETDATA devices.1.instances.0.commandClasses.91.data.srcInstanceId = 0 (0x00000000)
[2016-12-10 19:14:14.088] [D] [zway] SETDATA devices.1.instances.0.commandClasses.91.data.keyAttribute = 3 (0x00000003)
[2016-12-10 19:14:14.088] [D] [zway] SETDATA devices.1.instances.0.commandClasses.91.data.currentScene = 1 (0x00000001)
[2016-12-10 19:14:14.088] [D] [zway] SETDATA devices.9.instances.0.commandClasses.91.data.keyAttribute = 3 (0x00000003)
[2016-12-10 19:14:14.088] [D] [zway] SETDATA devices.9.instances.0.commandClasses.91.data.currentScene = 1 (0x00000001)
[2016-12-10 19:14:14.106] [I] [core] Notification: device-info (device-OnOff): {"dev":" (9.0.0.1) Button","l":"on"}
