Dear community,
I am completely new to z-wave and razberry. I hope this question is not redundant, but I didn't found anything on the web concerning the following:
I have a raspberry pi 3 with the razberry modul and as a first z-wave device a cyrus multisensor.
Everything works fine and I can work with the Web UI.
My question is now, is there a possibility to read out the sensors of the z-wave device via command line of the raspberry pi? That I can use the information of the z-wave devices in my own scripts?
Thanks for the suggestions and answers in advance
Cheers
Read out Z-Wave device on razberry
Re: Read out Z-Wave device on razberry
I'm not expert. I'm currently doing the setup of my crontab in my Raspberry pi.
Here is a french website : http://www.magdiblog.fr/domotique/contr ... -razberry/
At the end there is some examples of script like :
wget -o ./z-way.api -O ./z-way.api http://127.0.0.1:8083/ZWaveAPI/Run/devi ... %28$val%29
This particular command line doesn't work for me. I opened a post yesterday to understand why this command line doesn't work when the same url works in a web browser.
I'm still looking for a solution.
Let me know if you find a solution.
You're my booster. I found the solution in this forum : https://forum.z-wave.me/viewtopic.php?f=3419&t=22778
To do this from the command line you need to authenticate first and save a session cookie...
wget -q --header "Accept: application/json" --header "Content-Type: application/json" --post-data '{"form":true,"login":"admin","password":"admin","keepme":false,"default_ui":1}' http://127.0.0.1:8083/ZAutomation/api/v1/login --keep-session-cookie --save-cookie /tmp/zway-cookie.txt -O - 1>&2 >/dev/null
Then you use that session cookie for all subsequent requests with --load-cookies.
wget --load-cookies /tmp/zway-cookie.txt "http://127.0.0.1:8083/ZWaveAPI/Run/devi ... ].Set(255)" - O - 1>&2 >/dev/null
I hope it helps.
I hope it helps.
Hi gazier20,
Thank you for your answer, that helped a lot.
I didn't quite managed it to get it working with the "wget" command but on this page (http://razberry.z-wave.me/index.php?id=13) I found the following which works for me:
Get a token with the following command:
Then for example one can extract the value of a temperature sensor (or any other sensor) with:
"ZWaveAPI" can also be exchanges with "ZWave.zway". The option "-g" in the curl command assurs that square brackets can be used in the link.
To also Set the values of different devices one can use the following (example for a command class SwitchBinary):
The syntax of the available API commands can be found here: http://razberry.z-wave.me/docs/zwayDev.pdf
Maybe this is helpful for some people.
Greetings!
scorpion
curl -i -H "Accept: application/json" -H "Content-Type: application/json" -X POST -d '{"form": true, "login": "admin", "password": "admin", "keepme": false, "default_ui": 1}' 192.168.0.62:8083/ZAutomation/api/v1/login -c cookie.txt
curl -g http://192.168.178.88:8083/ZWaveAPI/Run/devices[4].instances[0].commandClasses[49].data[1].val.value -b cookie.txt
curl -g "192.168.178.88:8083/ZWaveAPI/Run/devices[6].instances[0].commandClasses[37].Set(1)" -b cookie.txt
Greetings!
scorpion
