Comet Thermostat with Razberry
andyg366
Post by andyg366 »
i am using Razberry with a number of actors for some time now, installed and configured everything myself w/o bigger problems.
But now i bought 2 Comet Thermostats and am completely lost and there seems to be no documentation at all.
The inclusion installed 4 Apps, 1 On/off switch called Operation, 1 Dimmer, 1 Slider from 0degrees to 40 and one display that shows the actual temp.
The on/off is always off and cannot be switched, the Dimmer jumps immediately after setting back to 0, the temp slider can be changed but it has no effect on the Thermostat at all. The temp display is updating only every few hours.
When i go into expert mode both Thermostats are always in deep sleep and i have no idea how to wake them.
I tried everything but to no effect, they just wont work. Only the Slider on the Thermostat itself is working correctly.
Please help
regards
Andy
Re: Comet Thermostat with Razberry
You should check the manual of Comet. The slider is for direct control of the valve and works only in special mode. Thermostats should accept values every wakeup. You could wake it up by button press.
You can ask people who have Stella Z - they are same in terms of Z-Wave. There are many users with these thermostats on the forum.
onovotny2@gmail.com
Post by onovotny2@gmail.com »
Hello, wake up time for this device was the biggest problem for me. I was able to set it to 3600 seconds in expert mode but I did not expereience better performance. The temperature has been updated every 24 hours and setting as well. So 2 different settings in a day was impossible.
With the current version of the Razpberry firmware and after restarting the Raspberry I have experienced better communication than at the time of first instalation. I don't know what has been changed but now the device works as expected.
