Philips Hue app?
klaasjoerg
Re: Philips Hue app?
Post by klaasjoerg »
Okay, double click helped.... ;-)
I selected "PhilipsHue"-App
Worked basically now, but do not really now how to get informations about hue-app shown...most of the times it's interrupting in automation-scripts but nothing really shown for hue at all....
(Unless I completely misunderstood this whole tool)
Just a console.log should work - place a console.logJS(...) as mentioned above to see the structure of the object.
klaasjoerg
I've no clue how this nodedebugger really works and how to use it properly. After playing around with it some time, i simply choosed to redirect stuff to console.log to get at least some results.
So finally I simply added console.log(+JSON.stringify(rsp)); to get some further object informations...
Here the results:
1. "deviceLights" is empty
2. "rsp.lights" is also empty
only
3. console.log(+JSON.stringify(rsp)); gave me the following results (shortened...)
So, that looks good to me so far.
	"status": 200,
	"statusText": "OK",
	"url": "http://192.168.1.54/api/XXXXXXXXXXXXX",
	"headers": {
		"Access-Control-Allow-Credentials": "true",
		"Access-Control-Allow-Headers": "Content-Type",
		"Access-Control-Allow-Methods": "POST, GET, OPTIONS, PUT, DELETE, HEAD",
		"Access-Control-Allow-Origin": "*",
		"Access-Control-Max-Age": "3600",
		"Cache-Control": "no-store, no-cache, must-revalidate, post-check=0, pre-check=0",
		"Connection": "close",
		"Content-type": "application/json",
		"Expires": "Mon, 1 Aug 2011 09:00:00 GMT",
		"Pragma": "no-cache"
	"contentType": "application/json",
	"data": {
		"lights": {
			"1": {
				"state": {
					"on": true,
					"bri": 150,
					"hue": 10233,
					"sat": 154,
					"effect": "none",
					"xy": [0.4945, 0.3911],
					"ct": 432,
					"alert": "none",
					"colormode": "hs",
					"reachable": true
				"type": "Extended color light",
				"name": "Stehlampe Kühlschrank",
				"modelid": "LCT007",
				"manufacturername": "Philips",
				"uniqueid": "00:17:88:01:10:25:5a:2a-0b",
				"swversion": "5.50.1.19085"
			"2": {
				"state": {
					"on": true,
					"bri": 150,
					"hue": 10497,
					"sat": 133,
					"effect": "none",
					"xy": [0.4775, 0.3902],
					"ct": 399,
					"alert": "none",
					"colormode": "hs",
					"reachable": true
				"name": "Stehlampe Esszimmer",
				"uniqueid": "00:17:88:01:10:4a:bd:13-0b",
			"3": {
				"state": {
					"on": false,
					"bri": 254,
					"hue": 11799,
					"sat": 254,
					"effect": "none",
					"xy": [0.5568, 0.4299],
					"alert": "none",
					"colormode": "xy",
					"reachable": true
				"type": "Color light",
				"name": "Aussenschrank",
				"modelid": "LST001",
				"uniqueid": "00:17:88:01:00:ce:38:72-0b",
				"swversion": "5.23.1.13452"
and so on,. and so on....
bedaone
Post by bedaone »
I've been looking into the app as well, found the following additional issues in the createDevices function:
- The "lights" are located in the "data" structure, so change rsp.lights --> rsp.data.lights (line ~97)
- The deviceLights array is indexed incorrectly, change "deviceLights.lightId.state --> deviceLights[lightId].state"
- The call to createDevice uses an incorrect param, change the last one to "uniqueId"
Overall, my createDevices function now looks like this:
PhilipsHue.prototype.createDevices = function(rsp){
        console.log("PhilipsHue Create Devices");
        var moduleName = "PhilipsHue",
            self = this,
            deviceLights = rsp.data.lights;
        var lightId = 1;
        while (deviceLights[lightId].state != "undefined" && lightId < 5) {
                var device = deviceLights[lightId],
                    state = device.state.on,
                    brightness = device.state.bri,
                    color = device.state.hue,
                    saturation = device.state.sat,
                    uniqueId = device.uniqueid,
                    name = device.name;
        self.createDevice('light', lightId, name, uniqueId);
        lightId++;
...and devices are now created for my Hue lamps. Unfortunately, there seems to be more issues when attempting to use the created devices. For the moment, i'm having more luck with the app by Minux, which is working well.
Indeed, looking on the logJS output rsp.lights -> rsp.data.lights wil be the correct fix.
Minux
Post by Minux »
Hello, can someone explain me where come from the official version ? Just by curiosity. I will add github repo as soon as possible.
klaasjoerg
Uuhh...have been debugging a bit further, and to be true:
The current version of this app/module is not working well with Hue-Lights at all.
After some further tweaking, at least now it works so far, although there is no status-refresh implemented and also no "real" color selections.
However, before I am going to tune this up for myself only, is there a github-Project page for this app to branch somewhere or should I rewrite it only for myself?
I don't know who is owning this in git. Will ask colleagues. But if you make that fix, we will with pleasure accept your pull request to share with others
luispedro
Post by luispedro »
Sorry for a quick of topic.
I'm looking for the "PhilipsHue" app on the AppStore but I can't find it!
I'm coming from Domoticz and very new to Z-WAVE>Me.
Can someone point me out the way to get that app which is the main reason I was on Domoticz?
LP
It is called Philips Hue. Make sure to look in Online Apps and reset "Featured" filter (check All)
