Z-Way Fahrenheit config Defaults setting
Posted: 02 Nov 2016 08:09
by vlad
I set Fahrenheit field to "1" in Defaults and forced interview on sensor ( Vision PIR with Temperature).
I get correct reading in Z-Way UI but with Celsius label, like this 78C... should be 78F.
How can I fix it?
Re: Z-Way Fahrenheit config Defaults setting
Posted: 02 Nov 2016 17:54
by Z-Wave Support
we have tested the device.
It cannot transmit the unit of the Temperature.
The default unit for temperature is °C.
Z-Wave Support Team
Posted: 04 Nov 2016 05:27
by vlad
Yes, I have tried both ways, when I set Vision PIR sensor to transmit in Fahrenheit - sensor just ignore it and send value in Celsius. So, in ZWay UI I have 25C as a temperature.
If I set Fahrenheit field in /opt/z-way-server/config/Defaults.xml file to "1" - the z-way-server will convert C into F internally by using formula ( C * 1.8 + 32 ) so UI will show number 77 BUT the label after that number is still char 'C' not the char 'F'.
So, how can I fix that "cosmetic" issue?
Posted: 04 Nov 2016 12:42
by Z-Wave Support
please restart your Z-Way System.
Exclude your PIR Device and include it again.
Then you have the Temperatur in Fahrenheit.
Z-Wave Support Team
Posted: 04 Nov 2016 16:53
by vlad
Yes, that did the trick.
Previously, I just did forced re-interview and that did not update char "C" into "F".
