Recommend a good zwave thermostat for vera edge?
Posted: 19 Nov 2016 15:29
Hey guys I'm looking for a good zwave thermostat to remotely control my heater/thermostat.
I'm not sure which one would be compatible with my system.
I have a gas furnace that heats water to circulate thru the old style stand up radiators, along with some new style baseboard water heaters.
My current thermostat is set to electric which is connected to a wire down to the furnace.
I believe when heat is turned on it simply completes the circuit connecting/jumping the 2 wires that go to the furnace turning it on. So I would likely need an electric setup, The switch on my current thermostat is set to electric.
So can someone recommend a nice looking cheap thermostat to comunicate with vera edge for remote management?
I realize this is a zwave forum but maybe someone has a similar setup and any help or suggestions would be greatly appreciated.
