Some questions on UZB1
Posted: 05 Jan 2017 02:22
I'm a newbie in the world of domotics, so sorry in advance if some of my questions are not "high-level"
I'm currently testing a "proof of concept" installation using my Raspberry 2 with Jeedom distribution + your ZWave UZB1 stick + 1 Qubino ZWave controller.
I finally manage to get the things working quite correctly, but I've some questions left:
1) Initially, I had 4 nodes recognized by Jeedom: node 5 was the Qubino, node 1 was UZB1 and node 2 and node 3 appeared dead (I've no other Z-Wave apparatus yet). I've seen elsewhere on the web that I was not the only one to have such 2 dead nodes (ex: https://github.com/cdjackson/HABmin/issues/223). Jeedom allowed me to get rid off them pretty easily but I wanted to know what may explain these initial dead nodes: does UZB1 stores information about the equipment it was linked to? One explanation found in a forum was that the key was maybe not new (second-hand) and UZB1 remembered 2 nodes from a past installation. A similar explanation was that it was due to some factory testing. So does UZB1 really stores information (ie does it has some built-in memory?)? If yes, do you make some factoring testing which could explain the 2 dead nodes?
2) Sometimes, after a reboot of the Pi, the UZB1 is mounted on /dev/ttyACM1 instead of /dev/ttyACM0, so I have to change a setting in Jeedom to get the Zwave network working again. Is there a way to prevent that? I tried some settings with udev following some explanations found for USB (ttyUSB) but it didn't work.
3) About the range: I had initially some big issues concerning the range of UZB1 (seems a little bit less problematic since I deleted the dead nodes, to be confirmed). A 11-12mg range without obstacles (walls) was sometimes to much and the Qubino appeared dead. It seems short compared to what is announced (100m outdoor, up to 40 m indoor). Is there a way to know if it comes from the UZB1 or from the Qubino?
4) By the way: I've seen that Razberry version 2 has a better antenna compared to version 1 (I hesitated when I choose the ZWave controller between UZB1 and Razberry) : is it better than UZB1 concerning the range?
Another question on Razberry v2 : what is is power consumption compared to UZB1? And is it possible to use the GPIO power pins with a small sensor even if Razberry is in place?
Thanks in advance for your answers
