Current status is not correct
Posted: 19 Jan 2017 23:31
Hello.
I have an issue, that the current status from my devices not showing correct value after sending command (on/off)
Latest z-way version 2.2.5 on rpi and UZB as controller.
I have included a clip so that it will be easier to understand what I mean.
Let me just explain what you are seeing.
Iam sending on and off command from Node-Red to the MQTT Module in Z-Way, the commands is sent to the devices, both Set and Get, that is the reason I display the queue.
Every time I send command like this, one or more device is not reporting back the correct state.
But if i force an update of the device then it will be correct.
This is a very annoying issue. And I hope there is someone that have any ideas how to solve this.
Here is my proof
https://youtu.be/F62MK86A-Eo
Here is my proof
