I can not get it to work, and feel a bit stupid
What I want do do is:
1. Dimmer up/down a light Bulb as long as I hold on to the botton, when release, it should stop
And it would be a great feature to be able to set how fast i dimmers up/down in seconds
2. One push=switch off
3. Another push=go to same satus ( e g dimmed to 60& ) as it had before it was switched off
I thought this was working like out of the box, as I know all ordinary pushbuttom-dimmers works like this? It feels like you have to reeinvent the fire and the wheel again
I have tried to use dimmable scene and logical roles and such, but can only get it to log every push as an ON (or 20). If I push twice it logs another event from the bottom as ON (23), and if I hold on to it, it logs ON (22)
But in logical rules I can use parameters as Down Start or UP Start etc, but they dont work.
Im I missing something?
Andreas
