Cannot start Z-Wave binding
Isaksson
Post by Isaksson »
Okey, i just restarted the system after a change in Defaults.xml (discussed in another thread)
Now The system can't connect the the UZB anymore.
Cannot start Z-Wave binding: ReferenceError: ZWaveBinding is not defined
If I move the UZB over to my windows machine then there is no problem communicating to it.
I have tried to disable / enable the app Z-Wave Network Access
I have removed and installed again Z-Wave Network Access
I have rebooted the rpi, I have disconnected power to the rpi for over 20 seconds, changed the USB port, but same error every time.
I have also upgraded zway but so same version just to make sure all dependencies should be installed again.
Once again all my lights is off and the sun is on its way down, unfortunately we are getting used to this...
Isaksson
Re: Cannot start Z-Wave binding
Post by Isaksson »
With the help of PoltoS we manage to find out that there where some problem with a default lib on the rpi, no ide how it broke, and reinstall did not solve the issue, I had to reinstall os and restore backup.
