GE Smart Switch 14291 not pairing or resetting
gkraft4
Post by gkraft4 »
I have a new GE Smart Switch 14291 (z-wave plus), and a new RaZberry controller.
Firmware version v2.3.0
UI version 1.6.0
Built date 20-01-2017 15:23:37
Capabilities: SlM
When I try to add a device, then I can see the led light up on the RaZberry daugther card. Here ia the z-way-server log. I'm a newbie, so I'm not sure what steps I should be seeing.
2017-03-12 22:50:28.932] [D] [zway] SENDING (cb 0x08): ( 01 05 00 4A C1 08 79 )
[2017-03-12 22:50:28.933] [D] [zway] RECEIVED ACK
[2017-03-12 22:50:28.946] [D] [zway] RECEIVED: ( 01 07 00 4A 08 01 00 00 BB )
[2017-03-12 22:50:28.946] [D] [zway] SENT ACK
[2017-03-12 22:50:28.946] [D] [zway] SETDATA controller.data.lastIncludedDevice = Empty
[2017-03-12 22:50:28.946] [D] [zway] SETDATA controller.data.lastExcludedDevice = Empty
[2017-03-12 22:50:28.946] [zway] Job 0x4a (Add/re-include node to network): Ready to add - push button on the device to be added
[2017-03-12 22:50:28.946] [D] [zway] SETDATA controller.data.controllerState = 1 (0x00000001)
[2017-03-12 22:50:58.974] [zway] Removing job: Add/re-include node to network
[2017-03-12 22:50:58.975] [zway] Adding job: Add/re-include node to network
[2017-03-12 22:50:58.984] [D] [zway] SENDING (cb 0x00): ( 01 05 00 4A 05 00 B5 )
[2017-03-12 22:50:58.986] [D] [zway] RECEIVED ACK
[2017-03-12 22:50:58.986] [zway] Job 0x4a (Add/re-include node to network): Stop done
[2017-03-12 22:50:58.986] [D] [zway] Job 0x4a (Add/re-include node to network): success
[2017-03-12 22:50:58.986] [zway] Removing job: Add/re-include node to network
[2017-03-12 22:50:58.986] [D] [zway] SETDATA controller.data.controllerState = 0 (0x00000000)
[2017-03-12 22:51:19.115] [D] [zway] Job 0x4a: deleted from queue
[2017-03-12 22:51:19.126] [D] [zway] Job 0x4a: deleted from queue
When I try to do a factory reset on the GE Smart Switch 14291 (3 quick On presses and 3 quick Off presses), then the switch does not blink to indicate a factory reset.
Is there a way to for the RaZberry to force the GE switch to reset?
Re: GE Smart Switch 14291 not pairing or resetting
Try to exclude first
