Use best route first?
Posted: 19 Mar 2017 23:05
I'm not sure I understand this correctly, but I've read that the default z-wave behavior when transmitting messages is to first attempt to communicate directly with the remote device, and if that fails, to then attempt to communicate via the mesh network. Is this true? Is there any way to get the controller to use the known correct route *first*?
As an example, I get the following timings (Last packets (in 10 ms units)) for a device which does not have a direct connection to the controller (must go through one relay node):
186 6 213 245 105 41 123 40 415 30 7 114 104 291 97 81 7 163 104 182
The routing table for this device shows it as "Communication through 1 node. There are several routes". So the controller knows there is no direct connection to this device. Why does it keep wasting time and communication bandwidth attempting to contact the device directly for every command?
