enum device metrics in module.json?
piet66
Post by piet66 »
is it possible to enum the metric names of a special device in module.json? I want to give the operator a list of possible metric names depending on a choosen device. But I didn't found any solution. :(
At the moment the metric is entered as a string. My module.json looks like this:
"sensors" : {
    "items" : {
        "fields" : {
            "device": {
                "label" : "__device-label__",
                "helper" : "__device-helper__",
                "type": "select",
                "datasource": "namespaces",
                "field": "optionLabels",
                "optionLabels": "namespaces:devices_sensorMultilevel:deviceName"
           "metric" : {
               "label" : "__metric-label__",
               "helper" : "__metric-helper__"
and
"sensors" : {
    "items" : {
        "properties" : {
            "device": {
                "field": "enum",
                "enum": "namespaces:devices_sensorMultilevel:deviceId",
                "required": true
           "metric" : {
               "type" : "string",
               "required" : false,
               "default" : "level"
piet66
Re: enum device metrics in module.json?
Post by piet66 »
Nobody knows?
It would already be helpful, if anybody can tell, it's possible or it's not possible.
