Control Roller Shutter/blind wirelessly with stop command
infinite.player
Post by infinite.player »
Hello there,
I have a Razzberry with a Z-Way Server.
There is a Qubino Flush Shutter ZMNHCD installed to control the blinds via the
android app or with the Fibaro keyfob controller.
There are no switches connected to the Shutter Controller. But now I
need additional Switches in the wall. This should be a general up/down (double) hardware switch which should control the
shutter controller wirelessly (there is no cable connection to the shutter controller).
With a (double) switch controller at the hardware switch side this setup works but only to get the blinds up and down. But I would also like to stop the blinds as well with the hardware switch.
Does anyone had the same problem or have an idea to solve this problem?
Kind regards
Michael
