Qubino ZMNHDD1 cannot complete interview
Posted: 05 Jul 2017 10:18
by bierisplezier
Hi All,
I've been searching for a solution for a while now. I'm having problems with the Qubino ZMNHDD1 inclusion. I've got 4 instances of command classes which seems wrong. I've had this problem for a while now with all tested releases, currently running v2.3.5-rc12 with SDK Version 6.51.09 and Serial API Version 05.07
Screen Shot 2017-07-05 at 09.03.47.png (86.56 KiB) Viewed 10269 times
This shows part of the interview, in my case the instances run from 0 till 3. The extra instances comes from the fact that I've enabled the extra l2 and l3 input buttons I guess.
I've been reading in viewtopic.php?f=3423&t=22454&p=59637&hi ... DD1#p59637 and viewtopic.php?f=3423&t=22236&hilit=postfix&start=30 but none of the threads shows a solution for the qubino. Fibaro dimmers had a similar problem but that it's solved according the thread.
I've been playing around with the postfix novdev options but no luck there, @PoltoS is this something I'm able to fix from my side? And if so can you point me into the right direction?
If I cannot fix it from my side, is the razberry team willing to fix this the way Fibaro dimmer2 FDG-212 was fixed?
Re: Qubino ZMNHDD1 cannot complete interview
Posted: 06 Jul 2017 12:09
by Z-Wave Support
which device version do you have? ZMNHDDX H_S_P_?
We have test it with newest devices and see not a problem. Interview is complete.
We have test it in the last stable of Z-Way v2.3.4
Best regards
Z-Wave Support
Posted: 06 Jul 2017 22:57
by bierisplezier
Hi Support,
I've got a ZMNHDD1 H1S3P3 with secure mode enabled. Meanwhile I'll give the 2.3.4 version a try to see if the problem still exists.
Regards,
Marlon
Posted: 07 Jul 2017 11:17
by Z-Wave Support
ok we have test it with a newer Release Version from the device H1S3P4. I think it is a bug in the firmware from this device.
Best regards
Z-Wave Support
Posted: 07 Jul 2017 21:49
by bierisplezier
Thank you for the feedback, can you confirm that with the H1S3P4 version it works with secure mode? (Parameter 250 set to 1)? And l2 and l3 set to the binary sensor? (Parameter 100 set to 9 and Parameter 101 set to 9)? I needed to reinclude the dimmer to get the values processed.
That way I can convince the webshop to provide me with another firmware version of the dimmer.
Regards,
Marlon
Posted: 10 Jul 2017 11:04
by Z-Wave Support
Please follow instructions.
Include the device
Change Parameter 250 to value 1
exclude the device
include the device as secure
delete the Nodes on Associations group 1
add the Zway(Node 1) on Association group 1
Now is the dimmer is running.
Z-Wave Support
